Not happy with Dyno numbers at all!!!
Old 11-20-2004, 11:07 PM
jpz28's Avatar
Default Not happy with Dyno numbers at all!!!
It's been a while since I have logged on I have been going to UTI and work so I haven't been able to log on and check the site out...any ways I dynoed my car and the numbers I got were so dissapointing that I know there mustbe something wrong with the dyno at school or something.....I have the following mods on a a4... 1.Hooker LT/no cats...
2. Hooker exhaust converted into poor man's Borla
3. Ported TB from Jantzer
4.MTI lid w/Holley powershot and FTRA
5.ASP Pulley
6.3.73 gear
7. all the Free Mods
8. NGK tr-55 w/ taylor thundervolts
9.stock internals with 02 simms
10. no codes with fresh new 0W-30 Syntec GTX
from Germany...
I dynoed at 297.8 hp and 331 TQ!!!......Either I didn't do it right or something but I know I have more just wondering what should I put out???
thanx!!!
Old 11-20-2004, 11:19 PM
Restricted User
CAT3's Avatar
My buddies 98 SS with near same mods and A4 put out about 276rwhp and he runs a dyno shop so there was no mistakes made in the run. Still runs decent times, but Dynos are good for tuning. Sorry I cant help you out.
Old 11-20-2004, 11:37 PM
5POINT7's Avatar
That is a poor hp number, but tq looks good for your mods.
Old 11-20-2004, 11:46 PM
Killer_Bluebird's Avatar
If it was a mustang dyno it sounds about right. If it was a dynojet the numbers are a bit low by about 10-20 hp. If it was on a dynojet it looks like time for an LS6 intake manifold. Your stock LS1 manifold may be limiting your intake and exhaust mods. I dynoed 332rwhp and 344rwtq with the mods bellow through factory exhaust. Although I may have a factory freak. BTW, I also removed the HPP3 programing for that run and gained about 3 peak rwhp from a previous pull.
Old 11-20-2004, 11:48 PM
jpz28's Avatar
Anyone else?...I am just asking because based on what everybody writes and saids here that I should at least break the 300 mark!!....is it the type of dyno or what..I run 13.00 flats with regular tires and lots of wheelhop...Am I in denial or what....?
Old 11-21-2004, 12:03 AM
13's flat is a good run. I've only manage a best 13.2 @ 105 with about 2.1 60' so there is a lot more on the car with decent traction. I'm thinking of getting MT ET streets early next year and watch my rear go
Old 11-21-2004, 11:42 AM
Moderator
davered00ss's Avatar
My results before the LS6 intake were 333 rwhp 342rwtq. I run 12.8 @110 in the 1/4. hope this helps. The hp seems low but the tq seems ok. possibly the corection factor is off on the dyno?
Old 11-24-2004, 06:04 AM
samz28's Avatar
maybe the tune sucks?
Old 11-24-2004, 06:15 AM
Gunslinger09's Avatar
I have a 98 A4 car as well and I dynoed that with similar mods. The only differences between your car and mine at the time are the Borla catback and the asp pulley I would think you should be at about 310-320 with those mods.
Old 11-24-2004, 02:28 PM
redsscamaroboy's Avatar
5.ASP Pulley
6.3.73 gear
from Germany...
thanx!!!
I hope you find more power than that,it seems kinda low on horsepower to me.
My 2000 A4 SS put down 289.9/297.7 (HP/TQ) dead stock.
And i ran a best of 13.2@105 2.0 60ft on factory tires with that power level.
My best 1/4 to date(without nitrous) has been 12.2 @110 1.62 60ft on DR's
I have Hooker LT's,ORY,Borla,NGK TR6's,SS4000(Yank convertor),SIMs,Lid,free mods and that;s about it....Still has stock 3:23 gears.
I hope there is something holding you back,and you find it soon. With a stock torque convertor i would have thought the results would have been greater than that.
Good luck.( P.S. any dyno numbers stock?)
Dave
Old 11-24-2004, 02:47 PM
BlueSix's Avatar
A4's dyno lower than M6's. The 3.73's will eat a few horse power, but not much. How was your A/F ratio? Have you had the car tuned? Some dyno's just dyno lower than others. Dyno's are only a tuning tool, it's the track times that matter.
Old 11-25-2004, 06:00 AM
PREDATOR-Z's Avatar
Taylor wires suck!
Try MSD's 8mm instead and a good tune.
Old 11-25-2004, 02:10 PM
xttc2000's Avatar
uti in illinois is notorious for having a low showing dyno. it wouldnt surprise me if the otehr campuses were the same.
compare your dyno run to the schools cars- they should have an LS1 there for you to look at. the illinois campus had a 99 ws6 that would put down only 271hp on their dyno with an lsx intake and everything else stock.
Old 11-25-2004, 08:59 PM
Turo's Avatar
jpz28, what's your trap speed in the 1/4 mile?
Old 11-26-2004, 03:05 PM
SSPEEDY's Avatar
Dude, don't feel bad about your numbers. Mine are in sig (with mods). I was devastated going from 369 locked, adding a new trans, ls6 intake and a retune then hitting 343
Can't take it to the track because the weather is lousy and I still haven't had a chance to break in the new trans (only 60 miles on it in two weeks).
FWIW, my last pass at the track was a 12.18 at 110.62 with mods listed in sig except for the ls6 intake and new trans. If I do the same or better next time out, I could care less what it shows on the dyno.
Old 11-26-2004, 08:15 PM
Dip Stick's Avatar
Nods dyno numbers seem low, but what you can actually do in the 1/4 prolly mean a lot more.
Im itching to see what sort of 1/4 times I can do this spring.
