ASP pulley leak?
ASP pulley leak?
my ASP crank pulley has been on around 6000 miles. its starting to leak now. any one else have this problem? should i put the old one back on? can i reinstall it and see if that works? thanks
Look where the pulley goes into the timing cover. See if it looks like thats where you leak is coming from.
If it is you need to remove the pulley and replace the seal.
Brad
Brad
