making custom ORY? HELP!
My father owns a stainless steal fabrication company..I was in the idea of making my own custom Y-pipe..Dont know too much about them so i was wondering if anyone had like pictures or plans of how to do so..Its going to connect to Flowtech LTs and borla exhaust..i dont know where the 02 simulator comes in to play...Can anyone help me out??
the O2 simulator plugs into the wire where your rear two oxygen sensors (would be) after the cats in the stock y-pipe. Since you wont have them, the simulators are plugged in so you dont throw a code. You basically hook the O2's up and tie them to something away from heat with a tie strap (well thats what i did anyway).
Well what i am saying is that u dont have LT's or anything like that where u would have to adjust the ends of the pipe to fit a larger diameter. I guess ur just basically trying to to get rid of the stock one cause it has that long *** flat part right. Well all u got to do is get a larger diameter pipe and cut in almost the same shape just make sure it doesn't get in anythings way seeing as how it is gonna be a bit bigger. The only thing i can think of is the fitment to ur borla exhaust. the pipes might be a different size. But thats all stuff u can check ur self on ur car.
