Help With Vibration
Old 11-23-2004, 08:21 AM
03SpiralGray's Avatar
Default Help With Vibration
I just had a TCI 2800 stall put in my C5. Now I have a weird vibration at 3k and 4k. I called TCI, they said they would check it out if I pull it out and send it in. I first noticed it in OD, and it also does it in park.
Anyone else experience this?
Old 11-23-2004, 07:12 PM
under_construction's Avatar
Does it happen in neutral also? If so, the converter might need to be re-clocked (bolts removed, then rotated 1 bolt hole on the drive plate - can be done in-car).
Old 11-24-2004, 07:41 AM
I haven't tried it in neutral. I assume it does, since it does it in park. I will try your turning method.
Old 11-24-2004, 11:29 AM
maddboost's Avatar
If it vibrates in park and neutral than its not the converter. When the car is in park or neutral the converter isnt spinning. What kind of trans mount are you running?
Old 11-24-2004, 12:05 PM
The stock ones I guess.
Old 11-24-2004, 12:11 PM
nitrorocket's Avatar
The converter spins in park and neutral, Its bolted directly to the flexplate!
Old 11-24-2004, 02:16 PM
maddboost's Avatar
Im sorry I worded it incorrectly. The converter is spinning but the pump inside is not. This proves that the vibration cant be caused by the converter.
Old 11-26-2004, 06:13 PM
Rock-On's Avatar
Default hey
Hey .. Any converter can vibrate, thats why they are balanced! I'd pull it and send it back. Hope this helps ........Dave
