Are Subframes safe lifting points for hydraulic lift?
Hi,
If Im having my car put on a lift is it safe to have the car lifted up by the front subframe points and the rear point on the subframes where they connect to the lcas?
Thanks!
-Lane
Thanks!
-Lane
NO!!! If they are welded on the welds might break... (kind of stupid, but i've seen it happen...). If you want to lift just one side, lift, place a jackstand then lift the other side and put in a jackstand and you'll have it up without liftind on your SFC's.
I don't think he's talking about SFC's I think he's talking about the Sub-frames themselves... I typically used the frame rails when putting my car on a lift... just make sure you don't block the lower control arms from movement in the back
look here http://www.installuniversity.com/ins...ift_points.htm
