SVO 30 lb. injectors good for 420 rwhp?
Old 11-25-2004, 11:07 PM
Importdestroyer's Avatar
Default SVO 30 lb. injectors good for 420 rwhp?
I already got a set, I went off of info on a chart out of Popular Hot Rodding and it said that 30 lb injectors would support 480 bhp or around 420 rwhp at 80%. I should be around that # with the mods in my sig next year.
Thanks, this site is the bomb!
Old 11-25-2004, 11:23 PM
C4VetteLS1's Avatar
SVO 30#'s are good for 550 rwhp or so....
Ive got a ton of customers cars making 500 rwhp on them (they are 36#'s or so @ 58psi
Old 11-25-2004, 11:38 PM
PREDATOR-Z's Avatar
Actually 30 pounders are 30 at 3 BAR at our fuel system (58 psi) 4 BAR they are 34.54 lbs.
I got these (SVO 30) and they are supporting 560rwhp at 93% duty cycle on juice {dry}.
Hope this answers your question.
Old 11-26-2004, 01:33 AM
Drew778's Avatar
Wow, push those babies
Are you still using the stock fuel line and rails?
Thanks
Andrew
Old 11-26-2004, 02:57 AM
PREDATOR-Z's Avatar
Thanks
Andrew
Yeap, but I got a Racetronix 255 PnP pump system with harness an an adjustable regulator at the rail at 62 psi (drops to 57>58 on 200 dry)
Old 11-26-2004, 09:06 AM
David Gordon's Avatar
I,m pushing 500 rwhp on stock injecters and plan on spraying it as well.
Old 11-26-2004, 01:50 PM
PREDATOR-Z's Avatar
You're probably maxing out your 28.8 injectors, not really good, especially in the upper rpms at wot.
Yeah you can spray them but not dry, and with wet you'll probably max out your pump.
Be careful that is all I have to say.
Old 11-26-2004, 06:52 PM
LS1TECH Sponsor
Racetronix's Avatar
Good / proper setup!
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
