231/237 cam TCI ssf3500 and a 2:73 gear??
and headers how will this work is it too much cam for the gear ? not enough stall for the cam?
please help me with my combo
I would like to leave the 2:73 gear in and maybe down the road put a 150 shot on it
I would like to keep it simple and would like some mid to low 11's
Well if you really want to keep those gears you need a 4000 or bigger converter. If you want to change the gear i would go 3.73s and maybe a 4000 stall. But it also depends on the tire size you plan to run. Just my .02 cents.
Location: sojourning....looking for my city whose builder and maker is God.
Originally Posted by mushroom281
bigger stall?? really why would a 4000 stall work better with a 2:73?
and I plan on full length headers also
I believe the false misfire is not always the reason people have had trouble with the converters not locking up correctly, too low a gear has played a much larger role in this than people have realized. 3.73 gears is your better choice for a high stall torque conveter.
Originally Posted by Lady Redhawk
2.73 gears + 3500 (or higher) torque conveter can = trouble. Even with a tranny cooler, you will cause the tranny to run very hot in low rpms in 4th gear (cruising). You need the higher gears to raise your rpms up. Running in 3rd gear all the time is a "fix" for this if that is what you want to do.
B.S., How is the tranny going to run hotter at lower RPM's if the tranny is locked up? And obviously it's locked up if it's running low RPM's. If that was the case every car with 2.73's would run hot in 4th.
I know a little about running 2.73's + 4200 stall. Ran that setup for around 40,000 miles. No heating up issues. Same gas milage as stock TC. Once ot locks up there is no differance.
If you can stand the looseness, I'd do a 4000 stall with that cam.
You do need a decent size cooler with that combo. raising part throttle shift points will also reduce the looseness and the amount of heat generated.
With 2.73s you will pull through the rpm band only twice and cross the traps at a relatively low rpm in comparison to peak power. I would think about a shorter duration, tighter LSA cam. For the same amount of overlap, you probably could have a beefier midrange and a slightly lower rpm at peak HP. Something like a 228/232 110 with a 110 or 111 ICL might be an interesting starting point.
I am curious as to why it happens to some but not all. Do you mind tell me if you leave the tranny in 4th gear while driving around town all the time?
Sorry about that.....it wasn't meant as an attack towards you personally. I believe there was something else that caused it not to lock. TCC solenoid maybe? Who knows? There are plenty of people running a "high stall" with 2.73's. Check out Yanks reccomendation for 2.73 cars at Tbyrne. A bunch of them call for a 3500 or bigger...
My point.....the gears didn't cause it. The converter not locking caused the problem. The converter should lock just fine and there is no additional heat when the converter is locked.
And while driving around town (as in 35 mph or lower) usually leave it in 3. On the highway always in OD (4th)
When I had my 3.23 gears I left it in 3rd a lot around town as well, but now I can leave it in 4th all the time with the 3.73s.
Retired Street Racer
like everyone said, ditch the 2.73's for sure. that cam is good on nitrous if you eventually spray it. as far as the stall...i would go with the 3500 if you are going to be spraying a lot all the time only. what i would do if i were you is go with the new tci 4000 stall. it has anti-balooning plates if you did spray it, and has been tested up to a 250 shot. that way if you keep it n/a, you have a better size stall, and if you spray, it is still going to be able to take it. just my opinion/advice. thanks.
I know a little about running 2.73's + 4200 stall. Ran that setup for around 40,000 miles. No heating up issues. Same gas milage as stock TC. Once ot locks up there is no differance .
And this is where I call BS. There is no way you ran a 4200 stall and kept the same gas mileage as stock.
On the highway. Made many road trips with it.
Not around town. Guess I wasn't too clear on that one. My bad.
OCTANE (interesting accidental side effect of a top notch port job leaving the swirl dam in...?!! )
Seriously, good comments in this thread. If you do mostly highway driving like
me, you CAN leave the 2.73 in (but back off on the cam or up the stall, as was said..). If all your driving is say, downtown Chicago under 30 MPH, you wouldn't want to do what I have..its a bit slushy at low speeds without the converter locked... and gears are good for a solid 0.2-0.3 / 2-3 MPH, all else being equal...JUST don't let anybody tell you the car "won't go" because of
the 2.73 gears - Would it help if I said I have a " 'Glide and 4.56 gears"?? Well, I do, and then it has a double overdrive to get home on the highway with - look at the effective overall gearing in the first two gears of a 4L60-E vs a 1.82 low Powerglide
