TSP Vs Lanes
TSP Vs Lanes
aright i wanted some opinions from people who have had duals done. i couldnt find any real good stuff using search so ill ask here....i am not posting this to give buisness to either side....
With clearence in mind and quality what true dual system is better the one from TSP for $420 or the one from LanesPerformance.com for $500
thanks to whoever responds to this
lanes uses the dr.gas x pipe setup and tsp doesnt i think...also im pretty sure there both manderal bent...i heard that the way lanes are shaped fit better up in the drive shaft tunnels so you have more clearence??
Dan
Originally Posted by matts22
Is that mandrel bent piping? Is it custom fit to your car? Does it use a Dr. Gas or similar X-pipe? These things add up and are the reason TSP and Lane's are more expensive.
he uses a regular bender but he custom fits everything to each car, he makes his own x pipe. He does a great job and his work looks great, most of the F-body guys around here go to him
I do like that TSP X-pipe, I still don't think it's a bad price for as good as it looks.
just how high can a pipe and/or muffler tuck with the torque arm right in the way?
all this talk about being WAY up in the tunnel is kinda crazy
i have a dual system and m y is damn near touching the t/a and my bullets are nearly touching it, im talking 1/4" away from it max and they are in no way shape or form way up in the tunnel
Dan
Originally Posted by zchgla
How much power/sound can you really lose from not being mandrel bent? have there been any tests?
I don't know, my car only has 2.5" pipe on it and it is plenty loud.
you are on the Cofba board aren't you?
I think he has an H pipe to clear the torque armm, because an X wouldnt...I could be wrong though.
My lanes has more ground clearance then my SLP y-pipe to 3" single. The only down fall is that my car is not a sleeper anymore. Anything over 3,000RPM my car screams RACE CAR, it's loud as fuc* now.I don't know that my car gained any hp over the 3" single no cat system that I had on there. I didn't gain any MPH or cut any E.T. I'm hoping a re-tune will help. The 11.5 pass in my sig was with SLP LT and a SLP firehawk cat back. My dual kit is still on for now but might come back off if it dosen't prove itself. I wanna make as much HP as possible being as quiet as possible.I'm starting to think that a 2.5" X pipe to bullets might have shown more gain.I guess it will pay off when I spray a 150 shot threw it next year, 10's here I come
Yes, i am. How much is your car lowered? Do you scrape alot?
yes, you are correct. It is lowered about an inch and it does scrape on speed bumps. I am putting Hal's all the way around and putting it back up to stock height for weight transfer
