Is it possible to have "quiet" true duals/X?
Old 11-28-2004, 11:05 AM
Steve Gunn's Avatar
Default Is it possible to have "quiet" true duals/X?
What muffler/bullet combos work? I want stealth. Is it possible?
Old 11-28-2004, 11:26 AM
a98ws6's Avatar
I have heard some quiet duals but they where made with 2.5" tubing. I am pretty sure he had Dynomax bullets.
Old 11-28-2004, 11:27 AM
cyphur's Avatar
Stealth isn't going to happen. Quiet is a relative term when you use it in the same sentance as true duals
Old 11-28-2004, 11:38 AM
zchgla's Avatar
magnaflow?
Old 11-28-2004, 12:41 PM
BLASTER's Avatar
edlebrock. are you going to run with cats?
Old 11-28-2004, 12:50 PM
WILWAXU's Avatar
Stealth.. then stick with a quiet catback setup.
I run a SLP Dual/Dual catback, when I get to the track I open the cutout
Old 11-28-2004, 01:13 PM
Z28Venom's Avatar
The quietest duals that I've heard to date are from Blaster.... but who really wants quiet true duals..
Old 11-28-2004, 01:17 PM
cyphur's Avatar
Originally Posted by Z28Venom
....but who really wants quiet true duals..
aren't borla xr-1's supposed to be comparitively tame? good sound tho.
Old 11-28-2004, 01:38 PM
Z28Venom's Avatar
Borlas are tame, but I wouldn't say quiet..
Right Click, Save As:
http://www.ls1sounds.com/true_duals/...mped_00Z28.wmv
Old 11-28-2004, 02:28 PM
Lane's Avatar
Cats help - the long 18" Twisters also help and there is usually no drone at all with them.
4x9 Magnaflows are great too, but to get any kind of ground clearance, you'll need to 'bash' in the floor-boards underneath the rear seat cushions.
It's possible. The quietest systems I've built - that still make great power are Macs, or stock '01+ manifolds(with or without cats), with a Dr Gas X - and 18" Twisters. Almost stock quiet at idle on a bolt-on car. But still sounds salty when you want.
Old 11-28-2004, 04:01 PM
Steve Gunn's Avatar
Thanks Guys!
Hey Lane,
I have Flowtech LT's... Is there room for dual 3"QTP's and cats before the X?
Do you have enough adjustability for different header configs? Does it fit with a spoohn tq arm?
PM me if this conflicts with sponsor rules.
Thanks!
Old 11-28-2004, 04:06 PM
HavATampa's Avatar
I want a semi-quiet dual exhaust system. Hey Lane, who sells those Twister mufflers? Their website showing distributors is broke it seems.
Old 11-28-2004, 04:11 PM
Steve Gunn's Avatar
Sounds sweet, Man!
Old 11-28-2004, 04:12 PM
Steve Gunn's Avatar
Do you have a link?
My main deal is being able to be quiet under 2K. The cops around here are on a rampage.
Thanks!
Old 11-29-2004, 11:56 AM
Lane's Avatar
Originally Posted by Steve Gunn
Thanks Guys!
Hey Lane,
Thanks!
There's room for the 'baby' Jet Hot cats(the ones they use on their catted Y), which we've found to work and perform very well.
Putting cutouts in front of the X will not give you any more power. We had a customer do that and dyno(heads, cam, nitrous car) - and he made about the same rwhp numbers, but lost midrange hp and 15-20 rwtq! His system is even reduced to 2.5" at the mufflers - and his duals go out the back under the axle where there's two MORE 2.5" Magnaflow mufflers... The comparison loss would be even greater IMO if his system was 3" all the way to the axle. The X crossover gives you power over open headers - especially the Dr. Gas! proven and patented X. We've seen it many times. I tested it on my bolt on car at the track. Ran 11.45 through the duals and mufflers and went 11.46 through open headers(with extensions).
Old 11-29-2004, 12:09 PM
BLASTER's Avatar
Any benefit in running the cutouts after the X? I've been thinking about doing that lately.
Old 11-29-2004, 12:21 PM
Lane's Avatar
Depends on the muffler(s) you're using. If the muffler(s) are straight through design, then the only thing you'll gain is loudness.
Old 11-30-2004, 12:23 AM
MachoCamacho's Avatar
x-pipe+spintech or borla xr-1 or magnaflow or edelbrock should keep it tame under 2000.
Quick Reply: Is it possible to have "quiet" true duals/X?
