Street Racing & Kill Stories Basic Technical Questions & Advice
cobra vs. camaro
Old 11-28-2004, 02:30 PM
seabirdak's Avatar
Default cobra vs. camaro
I was wondering which is faster in stock fourm a LS1 camaro or 03+ cobra?
ps i don't know if this is the right fourm.
seabirdak is offline
Old 11-28-2004, 02:38 PM
03SilverSnake's Avatar
The 03 Cobra easily
03SilverSnake is offline
Old 11-28-2004, 02:44 PM
Twitch's Avatar
I wouldn't say the 03 "easily", but the 04, *definetly*!
I've *never* seen the business-end of a Mustang, in 10+ years of racing Pontiacs, until the 04 Cobra came along.
That car's BAD AZZ. Too bad it doesn't come in automatic (I'm a lazy bastage, who often has to sit in traffic). The wife has a 99 TA and an 03 Cobra. She drives the hell out of both of them, and says the Cobra's only faster because she can ring it out with the manual.
Twitch is offline
Old 11-28-2004, 02:54 PM
Uhhh.. the 03 and 04 cobra have the same motor specs (see below) ... so how do you arrive at the conclusion that the 04 is faster out of the box ? I know people with both and it's give or take on both... now if you add some mods then that's a different story.. but both out of the box is not that different at least from what i've seen.
2003 Ford SVT Mustang Cobra Technical Data
Engine
Configuration
Longitudinally mounted, 90-degree V-8, cast iron block with aluminum heads, fully counterweighted forged crankshaft
Bore x Stroke
90.2mm x 90.0mm
Displacement
4,601cc; 280 cu.in.
Compression ratio
8.5:1
Horsepower
390 @ 6,000 rpm
Torque
390 @ 3,500 rpm
Specific output
84.8 horsepower per liter
Redline
6,500 rpm (fuel shut-off occurs at 6,500 rpm)
Valvetrain
Double overhead camshafts, chain drive to exhaust cams, secondary chains from exhaust to intake cams, roller finger followers with hydraulic lash adjustment, oval-wire beehive-shaped valve springs, four valves per cylinder
Intake valves
2 per cylinder, 37mm head diameter
Exhaust valves
2 per cylinder, 30mm head diameter
Ignition system
Distributorless coil-on-plug
Fuel system
Sequential electronic fuel injection
Induction system
Eaton™ Corporation Generation IV Roots- type supercharger with water-to-air intercooler
Boost pressure
8.0 psi maximum
Intake manifold
Cast aluminum, tuned equal-length runners
Throttle body
57mm twin bore
Mass-air sensor
90mm diameter
Exhaust manifolds
Cast iron
Exhaust system
Dual, stainless steel, 2.25-in. diameter; 3.0-in. polished exhaust tips
2004 MUSTANG COBRA DATE:
Longitudinally mounted, 90° V-8, cast iron block with aluminum heads, fully counterweighted forged crankshaft
Bore x stroke 90.2 x 90.0mm
Displacement: 4,601cc/280cid
Compression ratio: 8.5:1
Horsepower: 390 hp @ 6,000 rpm
Torque: 390 lb.-ft. @ 3,500 rpm
Specific output : 84.8 horsepower per liter
Redline: 6,500 rpm (fuel shut-off at 6,500 rpm)
Valvetrain: Double overhead camshafts, chain drive to exhaust cams, secondary chains from exhaust to intake cams, roller finger followers with hydraulic lash adjustment, oval-wire beehive shaped valve springs, four valves per cylinder
Intake valves : 2 per cylinder, 37mm head diameter
Exhaust valves : 2 per cylinder, 30mm head diameter
Fuel system : Sequential electronic fuel injection
Ignition system : Distributorless coil-on-plug
Induction system : Eaton Corporation Generation IV Roots-type supercharger with water-to-air intercooler
Boost pressure: 8.0 psi maximum
Intake manifold : Cast aluminum, tuned equal length runners
Throttle body : 57mm twin bore
Mass-air sensor : 90mm diameter
Exhaust manifolds: Cast iron
Exhaust system: Dual, stainless steel, 2.25-inch diameter; 3.0 inch polished exhaust tips
Old 11-28-2004, 02:57 PM
BigBronco's Avatar
03/04 cobra would win in stock form... against a stock ls1 F-body
BigBronco is offline
Old 11-28-2004, 03:00 PM
necrocannibal's Avatar
Let me say this, I have seen stock Cobras go 13.6 @ 106 mph at the track. And all day long consistent as it gets, almost like he was bracket racing and dialing it in. I have also seen them go high 12s stock at 110+ mph. Now I have seen LS1s go high 13s stock at 103 mph and high 12s stock at 110 mph ( My 01 WS6 did it). So if the 2 cars race and you have a great running LS1 and a not so great running Cobra it could/would be close. For the most part though a stock Cobra should beat a stock LS1 by 2-4 cars.
necrocannibal is offline
Old 11-28-2004, 03:30 PM
STF Veteran
99-LS1-SS's Avatar
Well I just ran a LS1 M6 with a catback, lid and free mods. We raced 3 times (2 from a roll and 1 from a dig)the other day and I pulled on him all three times. My car is bone stock and it only had 450 miles on it when we raced. Still had the paper tags on it.
99-LS1-SS is offline
Old 11-28-2004, 03:43 PM
When my car was bone stock i ran some as well and never lost.. but for all intents and purposes (stock v/s stock) an 03/04 Cobra is gonna come out the winner.
Old 11-28-2004, 04:01 PM
Administrator
unit213's Avatar
The Cobra should win every time. Here's the kicker though...alot of 03/04 Cobra owners are first time Mustang owners (including myself). It takes a while to get used to driving one of these things in comparison to a M6 LS1 f or y body. Therefore, you'll see a wide variety of times at the track. Personally, I only made about 5 passes in bone stock form. My best was a 13.5 @ 106mph or something like that. If I were to drive Brandon's Cobra, I'm sure I could squeak out a 12.7 @ 111mph or so now that I've perfected driving these cars.
An experienced LS1 driver will beat an inexperienced Cobra driver. The Cobra itself has more in it than a stock LS1 once drivers are removed from the equation.
unit213 is offline
Old 11-28-2004, 04:06 PM
I agree with unit.. pound for pound the 03/04 Cobra has the stock advantage but driving skills play a MAJOR part as well.
Old 11-28-2004, 08:04 PM
seabirdak's Avatar
: well i'm still debating which one to get, both sound awesome i've been eyeing the Z since 98, (I'm 23 yr. college student Now have a job making a couple thousand a week) but now that the 03 cobra is outvery tough decision.... thanks for all the info
Old 11-28-2004, 08:10 PM
STF Veteran
99-LS1-SS's Avatar
You'll pay more for the Cobra for sure. IMO the main advantage for the Cobra is the motor is forged and it already has a blower. There is a lot of potential. The LS1 motor isn't forged but you could get a forged motor and a super charger for the price that you would pay for a '03 Cobra. I don't think you will make a bad decision either way. Good luck and keep us posted.
Old 11-28-2004, 08:15 PM
Administrator
unit213's Avatar
I would never put a blower on a LS1. It's a waste IMO (sorry Tony & PSJ ). I'd go the turbo route.
If you're really making several thousand a week, although I can't see how for a college kid unless your selling coke, get the Cobra.
unit213 is offline
Old 11-28-2004, 08:22 PM
Yeah the 03/04 cobra motor is excellent.. relatively cheap mods = tremendous gains.. but i guess it comes down to which car you like the looks of and think you'd enjoy having.
Old 11-29-2004, 06:19 AM
STF Veteran
99-LS1-SS's Avatar
Yeah, I'd go the turbo route too but, they are about ~2K more than a blower. I was trying to give him the cheapest option.
Old 11-29-2004, 10:50 AM
generalchaos's Avatar
I kind of agree here. The 03-04 cobra is definately fast, ill give it that. but to me the looks of a mustang and just thinking of owning one are to me, no offence. And theres always the idiot GT owners crowd who will make you look bad.
just my .02
generalchaos is offline
Old 11-29-2004, 01:14 PM
STF Veteran
EvilStang's Avatar
I say sick with gettin the cobra...but depending on your liking's both are damn good cars....and yeah so you make a couple thousand a week huh ...... how about you donate to the fix justins cobra foundation....any donations will be benificial
Justin
EvilStang is offline
Old 11-29-2004, 02:04 PM
Administrator
unit213's Avatar
just my .02
Certainly a Neon looks better than a Cobra.
unit213 is offline
Old 11-29-2004, 04:07 PM
Slammed-am's Avatar
Cobra's look F*ckin sick. (In the good way) They just have this beefy/mean stance. And the forged/blower deal out of the box is really sweet. I have no ford bias, so for my next car I would def. consider a nice, used, 03+ Snake.
Slammed-am is offline
Old 11-29-2004, 04:16 PM
titanium barchetta's Avatar
What the hell does that mean?
You had never been beaten by a stang until then??
Were they all four-bangers or what?
titanium barchetta is offline
