Weld Draglites vs. Prostar Skinnies!
Old 11-29-2004, 12:00 PM
RedDemon2's Avatar
Default Weld Draglites vs. Prostar Skinnies!
Which has the better look and advantage between Weld Draglite Skinnies 15X8 rear // 15X3.5 front vs. Prostars 15X8 rear // 15X4 Front Skinnies? Want some opinions before I go and purchase some for my 1998 Trans Am!
Thanks for any opinions given!
Old 11-29-2004, 12:03 PM
Bad Blu Formula's Avatar
Draglites are lighter but the Pro Stars just look killer on Trans Ams.
Old 11-29-2004, 04:42 PM
Derek98z's Avatar
aren't prostars for f-bodies also 15x3.5? Mine are.
Old 11-30-2004, 08:43 PM
Larry's Avatar
Here's my 98 Camaro with 15 x 3 1/2 front and 15 x 8 rear.
On your Trans Am I think the Prostar will look better.
Old 11-30-2004, 08:57 PM
Juiced346's Avatar
I have draglights on my T/A right now. I have had both the prostars and draglights, IMHO Pro Stars all the way on a T/A. And yes the size is a 15x3.5
Dane
Old 11-30-2004, 09:57 PM
Tim 98z's Avatar
Dotto with DaneO. Prostars have a little more look to them. IMO
Old 12-01-2004, 09:17 AM
Derek98z's Avatar
I did see yesterday that 15x4 prostars can be had. But the amount of grinding to fit a 15x4 is sickening.
Old 12-01-2004, 10:31 AM
WickEdSix98's Avatar
i like draglites more. http://community.webshots.com/album/217112785HmqCvU
15x3.5 and 15x8"
Old 12-01-2004, 10:35 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,089 Likes on 717 Posts
I don't usually put up a link to my old car website but here it is:
https://ls1tech.com/moderators/psj/default.htm
The Pro Stars in the pics are 15x3.5/15x8 with 28x9x15 et drags in back.
The Draglites are regular 15x3.5 in front and XP 16x9's in back with 26x11.5x15 et streets.
Pro Stars are typically .5-1 lb heavier than Draglites.
15x4's won't fit on front due to the dish of the rim.
Old 12-01-2004, 03:48 PM
RedDemon2's Avatar
But are Pro Stars still way lighter than stock Trans Am Wheels?
Old 12-01-2004, 04:25 PM
my stock wheels and tires (16x8 w/245/50) weighed 42lbs a piece. The 15x3.5 draglites weighed 18lbs w/tires on the front, and the 15x8" rears weighed 42lbs with 275/50/15 BFG DR's.
Old 12-01-2004, 04:36 PM
Larry's Avatar
My 15 x 3 1/2 Prostar w/Moroso DS2 weighs 23#. 15 x 8 w/MT 26 x 10.5 x 15 ET Street = 35#
WickEdSix98,
That 18 pounds is sure light for your 15 x 3 1/2 Draglites. What tire do you have that's that light?
Old 12-01-2004, 08:24 PM
WickEdSix98,
I have a 165r radial on it. I was really suprised they were that light but i reset the scale and reweighed them a few times and it was 18lbs every time. Maybe the scale reads light
Old 12-01-2004, 10:43 PM
SJM Manufacturing Inc's Avatar
just to clarify for you guys:
the moroso DS2 weighs ~12lbs....The special 2 ply moroso is ~10...about the lightest out there. Your weld runner should be ~11 lbs, 23 lbs sounds about right... The VW tire (radial...not speed rated as well as mismatched for a rear et or qtp etc rear tire) should be heavier then the DS2 Radials in general are heavy. The VW tire is a whopping ~18 lbs! The scale used is way off...you need one that has a smaller resolution so there is less error.
You'll see weights all over the place due to difference scales used etc.
Regarding best rim....choose our Bogarts, they look the best, fit the best, lightest and we made them FOR F-bodies:-).
Steve
Pres.
Old 12-06-2004, 09:22 AM
RedDemon2's Avatar
Thanks for the Info!
Quick Reply: Weld Draglites vs. Prostar Skinnies!
