How to check for vacuum leak?
Old 11-29-2004, 01:01 PM
Uno99's Avatar
Default How to check for vacuum leak?
My car is surging at idle. From doing a little reearch I think it may be a vacuum leak. How do I check to see if there is a leak?
Old 11-29-2004, 03:13 PM
jammon46's Avatar
put some soapy water in a spray bottle, then spray the area that you think leaks. If there is a leak it will bubble up. I think you can use wd40 aswell.
Old 11-29-2004, 03:35 PM
horist's Avatar
I usually take some flammable spray (flammable brake cleaner works) and spray around where unmetered air can enter... if the engine RPM goes up around a certain spot then you've gotta leak there
Old 11-29-2004, 03:41 PM
badhoopty's Avatar
same technique as horist but i use starting fluid (either).
Old 11-29-2004, 04:12 PM
Smith4046's Avatar
Default Watch it guys!
When spraying flammable stuff - be careful NOT to get it close to hot engine parts. Did that once with carb cleaner - the top of the engine caught fire. Thank God I only melted my vacuum hoses - that was on an early 90's Citation II. TOTALLY my fault!
Good luck.
Steve
Old 11-29-2004, 05:06 PM
technical's Avatar
Yeah, but you found the leak.
Old 11-29-2004, 06:51 PM
jammon46's Avatar
and saw a cool light show
Old 11-29-2004, 06:55 PM
Hardtop00SS's Avatar
there's special machines that will hook up inline with a vacuum line and induce a smoke and will flow through the vacuum system and where it escapes is where the leak is.
Old 11-29-2004, 07:54 PM
Just Floor It's Avatar
horist and badhoopty are both right.
Quick Reply: How to check for vacuum leak?
