Pistons and rings being replaced, dealer doesn't want to hone.
I am having my pistons replaced do to excessive piston slap by my local dealer. They sent the pistons out to have the rods/pins pressed in and when they came back they did not put them in the order the dealer sent them out in, so they could not reuse the rings. Now they want to put new rings in but they don’t want to resurface/hone the cylinder bores. They said with the molly rings you don’t need to hone and the most important thing is that the cylinders are straight. The dealer said that the engine still had a good cross hatch finish on it and I shouldn’t worry. What do you guys think?
Make sure they check the cylinders for correct bore diameter and out of round. My factory block was replaced by GM for three cylinders being out of spec.....It had been torn down to replace the pistons but after the block was checked they replaced the entire longblock.
I may be wrong on this, but I thought the replacement rings had a friction coating on them to deglaze the cylinder wall. After a few minutes, the coating wears off, and the new rings can seat.
Originally Posted by HumpinSS
GO above the dealer and cal either customer service or the district rep and talk with them directly
It's not like the engine was put together that well from the factory to begin with. If you want the perfect engine rebuild, don't take it to the dealer for warranty work. And finally, don't worry about it. The new rings will either seat or they won't. If they don't then the dealer gets to re-do the work. I'll put money on they'll seat just fine.
Remember that GM pays the dealer for the warranty work. The dealer will not do anything for free. So unless either you or the dealer convinces GM to pay for a honing, you aint' getting one. And I wouldn't trust a dealer tech, who rarely does machine work, to hone your engine. That's the reason they sent the pistons and rods out in the first place.
Originally Posted by Gary Z
Factory tolerances today are significantly tighter and assembly much more precise than in decades past.
Really? What has changed in the past 10 years?
The improvement with respect to engineering has definitely made leaps and bounds. Specs are particular to a specific engine. Comparing the LT1 and LS1 specs isn't worthwile.
I would say that new rings in an engine with less than 36k (warranty?) without honing will be just fine. You could ask how I know this, but probably already know that answer.
The accuracy and precision achieved by the factory has not changed in many years. Specs change from engine design to engine design absolutely, but the factory has never been known to build a "tight" motor.
Manufacturing equipment and process has improved a great amount due to automation, digital interface, improved measuring techniques(through electronics instead of mechanical measurement) and robotics. This will improve greatly the precision and accuracy. Try making something on a old style mill or lathe, and try making the same piece on a modern design mill or lathe with a digital readout. The modern stuff ROCKS. Besides, you don't want all clearances tight. You want the rings to seal good (all depends on boost or nitrous), but loose bearing clearances often make more power hence when an engine breaks in it makes more power. Main bearings for an everyday driver you want maybe around .002" and you will see racing applications (especially drag racing where you have short races) you may want closer to .003"
I myself would rather have them check the roundness of the cylinders and not hone with a hand drill and cylinder hone they can do more damage with that thing than ever image it will remove more than just the glaze it will open up the clearances which is the problem in the first place better them not hone than have a crazied tech. make the cylinders look like a oversized egg in shape. The best way would be hone it out on the correct cylinder hone not hand held type to .005 oversize and install correct oversize piston and rings. just my 2 cents.
Originally Posted by BBQLS1
Manufacturing equipment and process has improved...This will improve greatly the precision and accuracy.
Besides, you don't want all clearances tight...but loose bearing clearances often make more power hence when an engine breaks in it makes more power. Main bearings for an everyday driver you want maybe around .002" and you will see racing applications (especially drag racing where you have short races) you may want closer to .003"
Automation has improved precision ie. the process of repeating a task over and over with the same "exact" results. Doesn't guarantee accuracy. People are still involved. Automation has sped up production yes, but engines built from the factory are just mass produced parts. They are not race engines that were put together with stricter tolerances and blue printed.
Automation removes the human factor and can increase accuracy.
Tolerance are just that...windows. If a main is good between .005 and .006 then .005, .0055, .006 all work. If you want that .2hp from your engine go for it. Don't forget to index your plugs as well.
