The Best Cam Choice!!!!
WHAT IS THE BEST CAM OUT THERE. I WAS WANTING TO SWITCH TO TEXAS SPEEDS MAGIC STICK 3. ANY GOOD WORDS ON IT? CURRENTLY I AM RUNNING THEIR SINGLE PATTERN 231/598 CAM. IT IS A GOOD CAM JUST WANT MORE RWHP!
LS1Tech Co-Founder
1. Use the search feature.
2. Educate yourself on cam specs.
3. Make the best decision for yourself. Everyone has different goals and requirements for their own vehicle. No such thing as "best" cam.
We hope you guys use this site to educate yourself on this stuff, not just take advice from others.
look over to the right...and talk to all the venders about what your looking for. Texas Speed has a big christmas special going on. Don't take any of these postings the wrong way!!! We are trying to help!!!! The ls1 venders will be able to answer your ?'s better then most of us since its them that R&D the cams that they supply. Make sure you know what you want....and the combo you are going to use.....change anyone of them .....and you"ll be picking another cam......heads/gears/exhaust/intake/weight of the car/tire size....and more....trust me I did this and feel like the one I got will do the job......bigger isn't many cases.....match the cam to your setup....for all you know, if you already have a cam and want alittle more power...changing the heads for example may give you the power your looking for.....Good luck!
