High-Mileage block, okay for re-build?
Old 12-01-2004, 06:29 PM
Slow98TA's Avatar
Default High-Mileage block, okay for re-build?
I am wondering if a block...JUST the block itself can be just as good as a fresh brand new bare block, if it's got over 100k miles on it? Basically stripping the block down to bare, and re-building it from the ground up. The motor lost the oil pump, and spun a rod bearing, since there is now damage to the crank, and I don't want to cut corners on this one, which onen would be the best way to go (cost wise) buy a stock type crank (new) or, go ahead and do a stroker motor now, while the opportunity is here? How much generally does a stroker set-up run vs. a stock-inch build up? Not looking to build anything too radical, but would like to make a street-friendly car, capable of 125-ish mph traps, full weight with 4.10's and a 6-speed.
Thanks In Advance Guys,
Jason
Old 12-01-2004, 06:43 PM
Byter's Avatar
I'm not an engine builder or anything, but there are a lot of really good builders out there offering blueprinted, balanced, machined 346 shortblocks for under $3000.00 with a warranty. If you want forged parts, it can be less than $3500.00. Many of these shops are LS1TECH sponsors, Keith Craft Motorsports, AP Engineering, LS1Speed, and many others.
Unless you really want to go through the experience of a build-up, that's the way I would go. Just my $.02...
Old 12-01-2004, 06:46 PM
B18B1LS1's Avatar
High mileage blocks are fine if it's still in normal condition. They are already well seasoned. Good luck on the rebuild.
Slow98TA's Avatar
Well, wasn't really wanting to have to mess with a build-up, but I figured that it would be a little cheaper. I am 100% against using used parts, so I wasn't going to 1/2 *** it to get it done quickly, I would take however long it took to get it done right. Forged is DEFINITELY a necessity, b/c I am sure at some point, it's gooing to feel "Slow" so I would like to be able to spray on it without worrying about stock cast parts failing. My only fear of ordering a short-block, is how do you really know you are getting what you are paying for?
Old 12-01-2004, 06:48 PM
Slow98TA's Avatar
The block itself, I believe to be in good shape, with a TR230 cam, and a set of stg. 1.5 Lloyd Elliott heads, stock ls1 intake, TB, MAF etc the car made 389 rwhp...so it was healthy when it went **** up.
