PCM resets every time I start the car!
Old 12-02-2004, 07:15 PM
Christos's Avatar
Default PCM resets every time I start the car!
When I first got my Camaro, it was doing fine, and still is besides this issue.
I've noticed that almost every time I start my car, the gauges all swipe, and the trip counter has been reset to 0.
Has anyone had this problem? I'm not sure what is causing it.
Old 12-02-2004, 07:19 PM
Full-Force's Avatar
Every darn morning i get in it mine does it ... mine is a 99 also.
I found out by talking to folks on the board that it is common with the 99's.
I guess we are just stuck with it because buying another cluster for a 99 will probably do the same thing eventually.
I have noticed as well as others that it does it worst when the weather is cold. When it was hot mine didnt do it.
I dont think its hurting anything unless you reall need the tripmeter.
Old 12-02-2004, 07:24 PM
Christos's Avatar
I always hear how after doing mods, you are supposed to reset the PCM, and then drive around for a while so the car can re-learn itself.
Since our cars constantly reset, does this mean we are running in some sort of, 'learn' mode most of the time? I hope that doesn't hurt performance.
Old 12-02-2004, 07:55 PM
Ryan01228's Avatar
Your PCM is not resetting ... It is simply the gauge cluster.
Old 12-02-2004, 08:03 PM
Christos's Avatar
Sweet, I was worried.
Quick Reply: PCM resets every time I start the car!
