Wont work the 98 are a different animal. The harnesss are different and a few other things. 99+ is swappable but 98 stays with the 98
Actually it can be done, but it requires removing the wires from the harness and repinning the connectors. Its a lot of work, but if you have the 98 PCM pin outs and the 02's, it can be done. There are a few other things you will have to change, such as coolant temp sensors and etc.
