Impressions of the FAST LSX/FAST 90MM TB!!!!
As u guys know I just swithed from the LS6/PTB to the FAST LSX/90...
I did the mods to the throttle body (PEEN MOD AND THE SCREW MOD)
Ported the intake to match my heads and bolted everything up.
Retuned it and went to the the track in almost the same air I had 3 weeks ago.(within 50 ft)
Results
LSX/90 TB netted me a solid .16 in ET
LSX/90 TB netted me a solid 2.1 in MPH
U need to tune it as it wants more fuel (on my car)down low but it seemed pretty good up top (12.7 A/F).
Anyone wanting to do these mods--------->DO IT
Just do the tweeks to the TB and take your time installing the intake.
COMP U MAKE A GREAT PRODUCT!!!!!
Results
Results
Results
Could you either describe this modificaiton or link it to this thread? I would like more info... I am switching intakes and tbs is a few days. Thanks.
https://ls1tech.com/forums/generation-iii-external-engine/203226-well-made-cough-fast-90mm-throttle-bodies.html
Originally Posted by LawmanSS
This is a very long thread, but it should answer most of your questions about the problems folks are having and how to do the above mentioned mods:
https://ls1tech.com/forums/showthread.php?t=203226
That's just what I needed. Thank you. Looks to me like I should reconsider. Seems a lot of people are having issues with the FAST products.
Plus on the TPIS I still had the throttle hang up once in a while after I jumped on it hard, it would hang up around 2000 rpm's so I had to ad a extra carb. style throttle spring to fix the problem.
Thanks for the info.
I've heard that on a stocker, the LS6 and BBK 85mm is more than enough. The motor doesn't demand more than that. That's what I've been running up until this point and I've been very pleased.
The down side to this is now I have to buy another setup since I want to go bigger and badder. I kinda wish I had just bought the FAST stuff from the beginning and saved the money.
If you're not planning on going much beyond the stock internals, LS6 and BBK is a good combo.
BTW, my BBK never had any of the problems the FAST tb is having with sticking etc. It worked flawlessly from install to present day.
