Anyone Done This.....
Old 12-05-2004, 01:02 PM
LS2 Pontiac GTO's Avatar
Default Anyone Done This.....
Has anyone just done a head swap? Im think of doing factory LS6 heads or AFR LS6 heads. Im wondering will the stock cam be able to support all that extra flow? I really dont want to swap the cam if possible. Any thoughs?
Old 12-05-2004, 01:12 PM
M6HuggerSS's Avatar
why dont you want to swap cams? thats where are the power is....
Old 12-05-2004, 01:17 PM
cyphur's Avatar
you'll still need supporting mods to support heads fully. i don't see many mods in the sig, but if you're like me and don't list 'em...post them up!! we'd be able to help you out better
Old 12-05-2004, 01:21 PM
I'd like to keep the car drivable since its my daily driver. Also the cam would add more time and money. Thats why I was just thinking of doing heads.
Also I only have the AirCharger and MSD wires and plugs on the way. Im going to be doing a cat back a tune later also. Should I just stick with factory LS6 heads or opt for the AFR heads?
Old 12-05-2004, 01:30 PM
M6HuggerSS's Avatar
then go with a low dur. cam like a comp 212/218.... great power cam, and would pass smog and drive near stock....
youd really be better off just doing a cam swap..... it would be alot cheaper amd youd make more power than just a head swap......
of i were you i would ge tsome nice ported LS6 heads and swap in a mild cam....
along with a good exhaust set-up......
you could always just throw on a magnesun blower..... HOT ROD mag. just put down 415rwhp and 430rwtq with JUST a blower!
just think what it would do with a good exhaust and even H/C?
Old 12-05-2004, 01:36 PM
cyphur's Avatar
go for factory stock ls6 heads if you MUST do a head upgrade. you won't see as much from it since you don't have any supporting mods. its kind of doing things backwards, usually you do full bolt-ons and THEN cam and heads. not too many people out there running heads and cam w/o full bolt ons that i know of, and they prolly aren't gettin the best of times/numbers with that sort of setup either. full bolt ons are needed to get everything you can from a big mod like heads or a cam.
if you had to choose, get a mildish cam like a 224 instead of heads, you'll see a much better gain from it. since you have a brand new car you won't have to replace everything under the sun like i would(oil pump, timing chain, et cetera). although i'd still replace the TC w/at least a single JWIS. good luck!
Old 12-05-2004, 07:20 PM
NLang's Avatar
Additional cam duration alone would help fill the cylinders (what makes pwr) more than a set of heads could ever do alone. A cam would also cost 4-5 times less than a set of AFR's. Driveability with more cam overlap can be made no tougher than stock with a good tuner. Obviously depending on it's size...
Old 12-05-2004, 07:35 PM
pdd
pdd's Avatar
definatly get a small cam with the heads.
Old 12-05-2004, 07:38 PM
Thanks for all the info. I think Im going to go with the LS6 conversion package from Pace Its comes with everything i need and is still cheaper than a set of AFR heads
Old 12-05-2004, 08:34 PM
jrp
SN95 Director
jrp's Avatar
couldnt have said it better myself
hell, you could probably throw in some headers and a gt2-3 and make more power then you could heads only.
Old 12-05-2004, 08:35 PM
jrp
SN95 Director
jrp's Avatar
still not worth it, i suggest you research around more.
Old 12-05-2004, 08:45 PM
Well im shoothing for around 350rwhp. That package with a tune should
do the trick. Iam I missing something? I know I could probably read that number with various bolt ons but I'd like to keep the engine bay as stock looking as possibble, so its easy to pass the visual part of the smog inspection.
Old 12-05-2004, 11:49 PM
fastmatt98's Avatar
I've got a LPE GT2-3 cam (207/220 578/581 on a 118.5lsa) and let me tell you it idles better than stock. Thats a great cam for you.
Old 12-05-2004, 11:55 PM
jrp
SN95 Director
jrp's Avatar
if your only looking for 350rwhp bolts and a gt2-3, tr220 114, ect will get you there and still pass smog.
Old 12-05-2004, 11:59 PM
NLang's Avatar
Hell, I know of a 228/228-114+4 passing smog on 3 or 4 different CA cars. Very tame idle too.
Old 12-06-2004, 08:48 PM
Is this the cam you are refering to? Lingenfelter GT2-3 LS1 Camshaft and Valve Spring Kit If so, does anyone know what valve spring those are and what there
rated at?
Old 12-06-2004, 10:05 PM
fastmatt98's Avatar
That is the cam I'm talking about and as for the springs I can't tell you what kind those are but I'm sure thay are good up to a 600. lift. I just got some 918's for mine and they work fine
Old 12-06-2004, 10:25 PM
So what is this cam know for top end mid ragen low end? Also does it keep the 6200 rpm redline?
Old 12-06-2004, 11:29 PM
cyphur's Avatar
OK....now its time to tell you to search. There is TONS of info on this cam out there. Seach, and ye shall find. You can't just ask question after question and expect all the answers. You have to work for the info most of the time
Old 12-07-2004, 12:06 AM
Thanks guys. I did do a search on this cam. Not too much info out there but from what ive read this looks to be the cam for me.
