Upgrading injectors require upgrading fuel pump?
Just as the title says.
Do i HAVE to upgrade or add an aux fuel pump if i'm getting a set of 42lb/hr injectors?
Going to be running it in a stroked 5.3L to a 383 with an STS turbo.
You don't have too, but the motor might run rough. Your buying bigger injectors to flow more fuel for the FI set-up, you'll definetely have to upgrade the fuel pump when you start adding boost with big injectors.
Philip S.
Philip S.
