worst speed for ls1 A4 roll race?
Old 12-06-2004, 12:00 AM
Lostpatrolman's Avatar
Default worst speed for ls1 A4 roll race?
my friend is going to race an a4 ls1 trans am that has exhaust as his only mod. my friend's car is a manual, but slower, running a best of a 13.9. the trans am will go from a roll. so i was wondering what speed of a roll will benefit my friend most, since he has a manual and can select the gear. like maybe a speed where the ls1 a4 will be at low rpms but the transmission won't downshift. something like that, that could help my friend make it a more even race.
Old 12-06-2004, 12:05 AM
Blue2002SS's Avatar
32-40MPH
If you are around 30 or slower the A4 will downshift to 1st gear
Old 12-06-2004, 12:11 AM
Blue2002SS's Avatar
32-40MPH
If you are around 30 or slower the A4 will downshift to 1st gear.
Old 12-06-2004, 07:47 AM
john3daly's Avatar
Depends on what gears he has.....
Old 12-06-2004, 08:09 AM
darrensls1formula's Avatar
35 mph. Worst possible place to gun the gas with stock gears and more importantly the stock torque converter. But a nice 3500-4000 stall will fix that
Old 12-06-2004, 11:54 PM
2001 White Ws6's Avatar
Run the A4 at 25-30mph. Make it a good race. If you race from 35-40 then the m6 will have an advantage because of gear selection. This is with an A4 with 3.23 rear end. 2.73s then 40mph for the fairly easy win.
Old 12-07-2004, 08:07 AM
4mula's Avatar
35 mph is a bad dead stop for a stock A4.
a stall will fix that.
Old 12-07-2004, 10:21 AM
SSnakekiller's Avatar
The TA would have to be an idiot to go at ANYTHING over 32. If he agrees then it is just ignorance of not knowing his shift points.
M6 should eat him up if that is the case...
Even at 25-30 roll it should be a good race like White WS6 said...
Old 12-08-2004, 05:29 PM
Mazzenger's Avatar
I say run from 25mph roll and then one more time from a 65mph roll.
That would be a couple of good races.
Old 12-08-2004, 05:52 PM
Ryan1985's Avatar
Who races from a roll? A real race if from a dead
Old 12-08-2004, 06:01 PM
git_sum's Avatar
Racing from a dead stop has more to do with the ability of the driver, racing from a role has more to do with the ability of the car.
Old 12-08-2004, 08:33 PM
fast98's Avatar
depends upon his gears, my stock stall stock gear 2.73 z28 will go to first at 40, no my speedo isnt wrong.
Old 12-08-2004, 09:49 PM
jxaxsxoxn's Avatar
Don't forget tuning. I had my downshifts tweaked a little and my A4 will drop down right at the perfect spot.
Quick Reply: worst speed for ls1 A4 roll race?
