Which is a good CAM and Rocker Combination?
Old 12-06-2004, 04:15 PM
RedDemon2's Avatar
Default Which is a good CAM and Rocker Combination?
Current Mods: ASP Pulley, Air Lid, Cut-Out, Hooker Headers w/ ORY Pipe, 3.73's and 125 Shot of Nitrous!
Which is a good Size/Brand: Cam and Rocker Combination I can use with my current Mods? Thinking of adding this Mods very soon! Thanks for any advice!
Old 12-06-2004, 04:36 PM
cyphur's Avatar
any cam and stock rockers
Old 12-06-2004, 04:40 PM
Z28Venom's Avatar
Stock rockers are fine...
Cam - ??? it all varies depending on application. What kind of car are you trying to build. Street, track, or some of both?
Old 12-06-2004, 04:41 PM
conan's Avatar
You would probly want a cam with more EX dur. & lift, than IN,for the nitrous aplcation.
Someone correct me if I'm wrong, Also think about the use of nitrous you might want to get some thing that makes good power with out it, unless you use it all the time. Thunder has good kits,pushrods,springs,Ect. Your stock rockers should work fine.
Old 12-07-2004, 09:07 AM
RedDemon2's Avatar
Thanks for the Info!!!!!
