what bellow for TPIS 90mm and stock MAF
Originally Posted by Kurtomac
also what are you guys doing with the PCV tube out of the valve cover?
are there coolant lines that go in/out of this tpis tbody?
No there isn't any coolant lines on the TPIS T/B. I'm running 85mm maf so I can't help on the bellows for a stock maf.
ls6 intake coolant lines are fine arent they?
Yes they are, I'll see if I can get Dark Age to post a couple of pic's for me of my fresh air tube & Small K&N filter on the pass. side valve cover so you have a Idea of what I did with mine.
Or you could just go into the bellow for fresh air. That's what I'm doing.
Originally Posted by DanZ28
I'm curious as well. How are people attatching their air lid to an 85mm MAF and then to the 90mm TB??
Dan
Dan
I've heard of someone stretching their SLP bellows to fit the 90mm, but I just bought this one:
http://shop.airflowonline.com/Mercha...tegory_Code=HH
smokin joe im still torn on either running a breather off the valve cover or running a tube into my bellow which i dont really like the idea of doing....we'll see....fireball had a good point with the unmetered air into the motor by doing a breather....maybe ill call TSP and see what they have to say
sweet thanks,...how did he connect that breather on the little nipple on the valve cover? and where did he get that k&n breather that setup looks sweet, is he using a AMW catchcan....i still need to do somethin like that
Ok as for the unmetered air when I took it in to get it tuned they said the ECM was having a little problem with the unmetered air coming in but it would learn it and adjust for it real quick which it did. As for the breather I used a small piece of 3/8" hose at the valve cover which connect's to a small blue fuel line elbow(bought at a local speed shop) and used another piece of small hose off the elbow to the small breather(bought at a local speed shop). Yes that is a AMW (oil accumulator) catch can with Dark Age's bracket. Oh thank's Al (Dark Age) for posting the pic's for me.
