Can I dump my current .bin file into spare PCM?
Old 12-07-2004, 03:55 PM
1fastWS6's Avatar
Default Can I dump my current .bin file into spare PCM?
Had my spare PCM reflashed by the dealer for my year/VIN. I am selling my current tuned PCM with my EDIT software. Can I just upload the current tune into the spare PCM or do I have to manually make all the changes to it?
Thanks.
Old 12-07-2004, 06:51 PM
horist's Avatar
Shouldn't be a problem as long as the OS ID and Checksum #1 match (read both PCMs and compare this) If they're different you can do the manual method... or could even go as far as using the HP Tuner Pro software to reflash your spare PCM w/an exact image of everything from your PCM
Old 12-07-2004, 07:06 PM
HumpinSS's Avatar
With the pro version you could just do a full re-write, that is if you have the pro-version
Old 12-07-2004, 08:53 PM
1fastWS6's Avatar
I just bought it so it's the pro-version. I'll look into doing a full re-write. Thanks.
