Call me stupid, but....
Old 12-07-2004, 06:49 PM
Kurtomac's Avatar
Default Call me stupid, but....
convos pros are 8.5 inch wheel correct, i was debating this with a friend for an 8.5" inch wheel a 26x10 et drag is too wide for that, he explains that mickey thompson and hoosier reccommends a 10.5" tire....so i explain maybe a 26x10.5 et street which is narrower than a 26x10 et drag, but he goes on that hes got 26x10.5x15 et drags which i didnt even know they made in that size as i thought it went 26x8.5 to a 26x10 in sizes...anyways am i wrong or is this guy full of **** and i went on to tell him hes crazy for running that size tire on that narrow of rim....lets hear it guys
Old 12-07-2004, 06:50 PM
Kurtomac's Avatar
and dont flame me on the convos i own 15x10 bogarts and use the 26x10 drags
Old 12-07-2004, 07:56 PM
Tim 98z's Avatar
I ran a 26x11.50 ETstreet without any troubles on a stock 16"x8 wheel.
Also now I run 325/50/15 ET Street Radial they are = to a 28x13.50 on a 10" wheel. Now problems here either.
A 26/10 ET Drag had a tread width of 9.6" or so. His rim is only 1" thinner than his tire. He is better off than I am.
Old 12-07-2004, 11:23 PM
SJM Manufacturing Inc's Avatar
26x10 drag is too small for the rim...sure you can do it, just like you see guys using a 315 on a 9.5 rim....both not recommended, though they do it...it pinches the tire too much.
There's alot of things I see folks doing, though it is not safe...those VW skinny tires are a pet peeve of mine...heavy as crap, and not safe above 85mph...but folks still do it as they try to save a few dollars over the safety of themselves and others.
Not sure why they don't either pick a rim that fits the tire, or pick a tire that fits the rim...being that centerlines don't work well with F-bodies due to BS issues, they are stuck to using smaller rims with smaller tires or choose a shorter rear to run the larger rims with larger tires.
Your absolutly correct with your statements.
Steve
Pres.
Old 12-08-2004, 02:16 AM
JackZ28's Avatar
You're stupid!
j/k man! :p
Old 12-08-2004, 08:07 AM
Xsta Z 28's Avatar
Originally Posted by JackZ28
You're stupid!
j/k man!
Hey, thats what I wanted to say!
Old 12-08-2004, 08:25 AM
mySStery_machine's Avatar
I'll add to the fray.
Stupid...butt.
