Gasoline in oil, help!
I checked my oil today and noticed that the oil smelled like gas. Not to sure what is causing this. I have 42lbs injectors in right now, and tuned the flow rate so that it would not run pig rich, but still not 100% sure what my A/F is at. My motor was built for nitrous and know the rings on the pistons are gapped for this. Could this be a normal thing for a nitrous motor, some fuel could sneak by the ring gap and get into the fuel? Not to sure what could cause this other than that.
I notice over time the fuel will build up in the oil (3k), but it really started when I installed the cutout. Whats your input...
thanks, chris
thanks, chris
A lot of times your oil will smell like fuel even if there isn't much in there. Get an oil analysis done to find out for sure how much is in there. I smelled fuel in mine once, but the oil analysis showed only 0.5% fuel, which is completely normal (anything under 1 or 2% is fine)
Originally Posted by chrdij
not too sure any place that will do an oil analysis, but would be great to know. I am going to run hp tuners and see what the voltage is looking like on my o2's. Thanks 4 the help everyone!
www.blackstone-labs.com
