Z06 Cam Specs
Old 12-08-2004, 08:52 PM
Crazy Man's Avatar
Default Z06 Cam Specs
Can anybody tell me what a stock 2003 Z06 cam specs would be. Thanks
Old 12-08-2004, 09:03 PM
Joker's Avatar
204/218@.050 Duration, .551/.547 Lift, 117.5 LSA is the specs of the ZO6 cam I believe.
Old 12-08-2004, 09:07 PM
Crazy Man's Avatar
Thanks Man!!
cyphur's Avatar
the chart i have says 204/218 551/541 117.5 for 2002+ z06 cams, fwiw.
Old 12-08-2004, 09:12 PM
Crazy Man's Avatar
Thank you also!
Old 12-08-2004, 09:59 PM
jz06man's Avatar
These cam spec's are stated are correct!
Old 12-09-2004, 02:52 PM
MachoCamacho's Avatar
what are the specs of the pre 02 model z06's?
Old 12-09-2004, 03:05 PM
NviouSS's Avatar
204/211 .525/.252 116 LSA
Old 10-30-2013, 01:49 PM
BamaBobAlex's Avatar
Thumbs up
is this a 3 bolt cam or 1 bolt?
also, can it be installed a 5.3 ?
Old 10-30-2013, 01:58 PM
wildcamaro's Avatar
3 bolt and yes
Old 10-31-2013, 03:58 AM
joecar's Avatar
With -2.5 advance ground-in.
Old 10-31-2013, 03:15 PM
99Bluz28's Avatar
2002+ Z06 cam
...or with +2.5* retard ground-in....
204/218 117.5lsa -2.5, lift .551"/.547", IVC 43, ICL 120
Old 10-31-2013, 05:12 PM
joecar's Avatar
lol..
Old 11-02-2013, 10:02 PM
Centuryclubz28's Avatar
Default 2002 Camaro LS1 upgrade cam
I'm replacing/building a LS1 that thru a rod replacing with 98 LS1 covette engine
What cam spec would work well with the 4L60 ntrans in the Z28 and pass emissions??
RT
Old 11-03-2013, 01:10 AM
99Bluz28's Avatar
Sent you a pm Centuryclubz28.
Quick Reply: Z06 Cam Specs
