Preload Question, Why 22 Ft-Lbs
I understand the process of preload but what I don't understand is why I have to hit the magic 22 ftpound in so many turns after 0 lash. Why couldn't I just reach zero lash and then go 1/16 to 1/8 turn past 0 lash in the case of camp Rs without veriffying that it happens at 22 ft-lbs?
what he said
you are comparing apples to oranges..
stock rockers are not adjustable...22ftlbs really has nothing to do with a zero lash although it is something past..
Comp Rs are adjustble..about 1/5 turn past zero lash cold..with comp r lifters.
Wow...1/5th of a turn past zero lash is all Comp recommends for preload...No wonder everyone says they make way more noise that stock lifters...
I Just did Crane Adjustables and they were 2 full turns (0.090") worth of preload after zero lash...
Peace...Gman
Peace...Gman
Comp recommends .008-.010" which is about 1/5 turn...no more noise than stock. They make more noise when they arent installed properly...soaked in oil, adjustable rockers with correct preload...
1- preload is an action on the lifter not the rocker.
2- there are 2 kinds of rockers
a-adjustables and non-adjustables >>>(stock units are non-adj)
On non adjustable rockers its 22lbs/ft trq after 0 lash of the pushrod.(nothing to do with preload of lifter), lifter preload with non- adj can only be done by either custom length p-rods or shimming the rock assembly stands.
b- on adjustables, no shimming needed, and past 0 lash, the rocker bolt has to be tightened to manufacturer specs. This could be 1/4 or 1/5 turn past or so (this has to be done hot).
