What performance upgrades can I get from a GM Dealer?
Ok, on the "other" forum, there is a deal for any GM parts at DEALER cost. This is an amazing deal that I would like to take advantage of. I was just wondering, what all could I really upgrade or buy that I might need later? I am going to do all the bolt-ons, heads/cam, etc. later so if you guys can tell me ANYTHING I should look into, please tell me. And you guys might want to check this out too.
I would imagine that it varies greatly by dealer, but I thought that a Corsa cat-back was the only thing GM actually "approved" of without voiding the warranty.
GM has a High Performance catalog that you should be able to get at any GM service center and they have areas for LS1's and F-Bodies.
BTW where is this at cost deal?
http://www.ls1.com/forums/showthread.php?t=541185
Let me know if they offer 1LE parts, as well as any decent upgrades you can find. Ill try to get a catalog too, but just in case.
Originally Posted by BadAndy
Do they have any 1LE parts?
#12363906(Under Camaro F-1)
'Extreme Sport Suspension Package for 1993-2000 vehicles':
Includes 1LE stabilizer bar, mounting bushings, link kit, track bar, assembly hardware, and instructions.
*Refer to Technical Note on P/N 12363941
#12480033 (Under Firebird)
'LS1 Hot Cam Kit':
1998-1999 LS1 0.525" valve lift with stock 1.71 ratio rocker arms. Includes high RPM valve springs.
Originally Posted by msbz_ls1
i thought ne upgrade from stock voided warrantys
If you do a mod, it doesnt just void the warranty altogether. It can void other parts potential for being covered under warranty but only if the mod you did made the other part/parts malfunction/break. For instance if you put on a K&N and then you threw a code cause of oil on your MAF they may or may not fix it. Its up to the dealer.
i think any gm performance parts will not void the warrenty, like aluminum driveshafts, LS6 heads, hot cam, 1LE parts
personally, i dont care about the warrenty, i like working on my car
