Where to set shift light with my cam? Help ASAP(track tomorrow)
Old 12-09-2004, 09:19 PM
Trevor_00Ws6's Avatar
Default Where to set shift light with my cam? Help ASAP(track tomorrow)
I just got my harlen shift light today, and im installing it tomorrow before the track... So i was wondering where i should set it at? I have a 7000 rev limiter(i know i know, ) Thats where my tuner put it and he is very respected in Texas as one of the best ls1edit tuners(Chris Robinson, OBSSSD).
I was thinking about putting it at 6500 or 6400... Shifting at 6600 or 6500... I dont want to rev it as high as Chris thinks... Shift at 6800!
Thanks Trevor
Old 12-09-2004, 09:43 PM
ATVracr's Avatar
Shift it at 6800 if thats what he said ... he is probably saying that because thats where that cam needs to be shifted for peak performance.
Set your light at 6700 by the time you see it and react .....6800
Old 12-09-2004, 09:49 PM
xttc2000's Avatar
when i had my tr224 cam in i was shifting between 6800 and 7000 shift light at 6600. the hp held all the way to 7000 surprisingly. you are running a biger cam, shift it at 6800.
Old 12-09-2004, 10:03 PM
Mazzenger's Avatar
Trevor00_WS6
how much power did you make after the cam?
Old 12-10-2004, 01:07 AM
Avengeance's Avatar
I have mine in the center air vent... angle it right and it works perfectly and is totally out of site.
*edit*
My bad I thought you were refering to mounting location *kicks self in the ****
Sorry.
Old 12-10-2004, 02:14 AM
Squintz Palladoris's Avatar
Depending on your reaction time to the light, set it either right on where you want to shift or a couple hundred sooner.
Brad
Old 12-11-2004, 12:26 AM
Umm, Im not sure how much I make now... I need to get it dyno'd bad. Hopefully I will be getting it done here really soon.
Old 12-11-2004, 12:36 AM
redrocketls1's Avatar
hmm where did u get that cam? is there a site for whoever ground it?
Old 12-11-2004, 05:53 AM
Bearcat Steve's Avatar
Brad
Given my reaction time, I would need to set it a couple of 1000 RPM's early!
Old 12-11-2004, 06:49 PM
custom comp cams grind
