What Cam
Old 12-10-2004, 01:42 PM
Ronnie Abene's Avatar
Default What Cam
What cam could anyone recommend to me useing stock heads and springs. Car is 02 z28 with automatic. 373 gears,lid,fast toys ram air,smooth bellow. Thanks
Old 12-10-2004, 01:48 PM
goober35's Avatar
That would be that stock cam. Look stock springs are good to what .500 lift. I dont know of a cam out there with that small of a lift other than the stock cam. If you will notice everone of use that has a cam has a set or aftermarkt spings. It is just the name of the game. You have to pay to play.
Old 12-10-2004, 02:04 PM
Blue Hawk's Avatar
I agree with goober35. You MUST change the springs when swapping the cam. Stock LS1 springs are simply not strong enough.
Old 12-10-2004, 02:25 PM
Thanks guys I understand.
Old 12-10-2004, 02:48 PM
LiquidFire350's Avatar
hey guys im slighty new to cams, what what you guys suggest with the mods i have listed in my sig, if i have to get new springs, i will
and this car is daily driven in the summer time
Old 12-10-2004, 03:32 PM
C_B64's Avatar
First mod would be a stall, You have to have a stall for a larger cam.....
Old 12-10-2004, 03:54 PM
luv2spd's Avatar
The TR224 is a great all-around cam.
Old 12-11-2004, 01:22 AM
Z-286speed's Avatar
Like everyone else has said, you need to change springs for a bigger cam. Depending on what you want, the 224 is a great all around cam, and then you have the MS3 and t rexs out there.
Old 12-11-2004, 12:11 PM
blkZ28spt's Avatar
You "need" two things before you get a cam. Headers and a new converter. Without headers you will choke the cam, and without the converter you will be stuck at very low RPM's where any decent sized cam does not make any power. Also, and this is more important the larger the cam is, you will have troubles with the idle raised because it will pull on the stock, very tight converter.
Old 12-11-2004, 02:54 PM
AZ Power & Sound's Avatar
with that gear ratio any larger cam is gonna kill you... get to a set of 3.42 gears, and at least a 3000 stall, preferably a 3600 or so... then get a nice cam. Ive put converter autos with stock gears in the 11s with just the LS6 cam and springs, then DEEP in the 11s with a 75 shot on top of it... but my usual reasoning with cams is if youre gonna do it, DO IT BIG! everyone I know that hasnt usually regrets their cam and wants bigger later!
Old 12-11-2004, 05:21 PM
blkZ28spt's Avatar
He doesn't want 3.42's........first post says he has 3.73's
Old 12-11-2004, 06:53 PM
hugger1975's Avatar
can i still do a head/cam with shorties?
i have edelbrock shorties, into a offroad y, then dumped.
i really want an evil cam befor i go long tubes.
any advice?
Old 12-11-2004, 07:06 PM
blkZ28spt's Avatar
any advice?
An "evil" cam will be choked by shorties. If you want an "evil" cam you should get LT's first. I know that it's hard to wait, trust me, I've had my car for 3.5 years and just ordered my cam yesterday. I am not totally sure what would happen with a big cam on shorties, it could be done i'm sure, but you wouldn't get the full benefit of your cam.
Old 12-11-2004, 07:18 PM
hugger1975's Avatar
thanx,
i kinda figured.
i hate to wait.
plus try explaining to the wife that u need to pay a grand for a few extra horses, when she knows that a cam would add alot more for a lil more money.
so i cold pull it off for a while, or its a bad idea all around?
Old 12-11-2004, 07:29 PM
blkZ28spt's Avatar
thanx,
i kinda figured.
i hate to wait.
I would do a search for cams and shorties, try different searches/forums see what you come up with. If it doesn't answer your question, or someone who KNOWS doesn't post in this, I would start a new thread about it. Chances are that a "what cam" thread won't get too many reads by people who answer those questions a lot. (trust me, i know that from experience as well)
Edited: Are you on stock converter? If so, you NEED a converter first.
Old 12-11-2004, 09:49 PM
thanks to everyone for the advice
i was thinking about 3.73 and a 2800 stall, im guessing i would need a bigger one?
Old 12-11-2004, 10:13 PM
blkZ28spt's Avatar
ABSOLUTELY go above a 2800 stall. True stall o ~3500+ would be a good minimum
. (vig3200, SSF3500, SY3500 for street tires, SS3600)
Old 12-11-2004, 10:17 PM
what about the gear, too much for a daily driver A4?
im not really concerned about gas mileage
Old 12-11-2004, 11:11 PM
blkZ28spt's Avatar
3.73 will be good. I'm thinking that SSonYourSix didn't realize you had 3.73's ~3500 stall (or bigger, if you can take it), 3.73's, and a big cam will be just fine.
Old 12-12-2004, 04:56 PM
im not the one who started this thread, he has 3.73s, i still have stock 2.73s, i was thinking about upgrading to 3.73s
