Which Magnaflow Mufflers for True Duals
Old 12-10-2004, 02:00 PM
98Blubrd's Avatar
Default Which Magnaflow Mufflers for True Duals
I am getting rid of the duals dumped and doing duals over the axle. Which Magnaflow mufflers is everyone using for the duals? I am thinking the Magnaflow's that are stainless steel one that are 4 X 9 and 14 inches long . Everyone just posts 4 X 9 and magnaflow has a bunch that are that size. Please do not bash my thread. I have had Borla XR-1's and know they sound good.
Old 12-10-2004, 03:20 PM
2_wacko's Avatar
https://ls1tech.com/forums/showthrea...aflow+mufflers Try searching threw this.
Old 12-10-2004, 04:16 PM
WSteve6's Avatar
I got stainless bullets from them, forget how long they are. They sound pretty damn good though.
Old 12-10-2004, 04:57 PM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
Replied to your PM.
BTW, if you're running TD's over the axle, bullets should be fine. Mufflers + Over The Axle TD's may be too quiet.
Good luck!
Old 12-19-2004, 10:18 AM
cm02WS6's Avatar
The Magnaflow PN 11366 is what I'll be using on my over the axle duals in a couple of months. This muffler has a body length of 11" instead of the other Magnaflows which are usually 14", which will save me some space. The tradeoff is that it has offset/center ports on it, but I think I can work with this for the extra 3" I save in length. It is also not available in stainless.
To answer your question, I believe that most people who talk about 4x9 Magnaflows are referring to the 14" body length ones with center/center ports.
Old 12-19-2004, 10:20 AM
!LS1 11 Second Club
I used the aluminized- offset Ovals on my old setup. Offset In/ Center Out. I believe they were reversible.
Old 12-19-2004, 12:49 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
I'm running a set of center in/out 3" inlet stainless mufflers from Magnaflow now, and I made 738rwhp thru them. Ask Tom@ls1speed.com for the part number.
