Camshaft Endplay Question...
Old 12-11-2004, 02:20 PM
Byter's Avatar
Default Camshaft Endplay Question...
I just installed my new camshaft and torqued down the retaining plate. By pulling on the guide pin, I can move the camshaft about an 1/8 of an inch back and forth in the journals. Is this ok?
It looks like the forward position is the correct one as far as lining the lobes up with the lifter journals. Is the camshaft "pulled" forward once I reinstall the timing gear?
Also, I followed JMX's instructions on LS1HOWTO. I didn't see anywhere (and did not remove) the camshaft position sensor when I took the old cam out and put the new one in. Is this ok, too?
I just want to get things straight before I button the front up.
Thanks...
Old 12-11-2004, 04:55 PM
I can shift faster than you.
Jason99T/A's Avatar
The camshaft will pull forward once the timing gear is installed. I'd check the end play once you have the gear installed, but it will tighten up considerably.
The factory calls for .001-.012" of end play on the camshaft for reference.
Jason
Old 12-11-2004, 04:58 PM
Byter's Avatar
Jason thanks. I took the new cam back out and compared it to the old one and they are indeed the exact same length so I figured I was ok. Thanks for the validation.
Old 12-11-2004, 06:27 PM
Beast96Z's Avatar
Like Jason said, once you install the top timing gear, it will sandwhich the cam and the plate together so it can't move.
