Dragaholic
12-11-2004, 05:28 PM
I dynoed the car when it was a 6 speed back in May of '03. Since then I have made lots of changes. The list consists of the mods that were on it when it was a 6 speed and if there is an arrow and a different mod, it’s the mod that's most recent and that was dynoed as of last night. If there is only 1 mod listed, then it was never changed. Anyhow, please let me know what you think of the numbers. I know that it wont put down as much on the dyno, but do you think that it should of put down more? I don’t know the percentage difference between an auto. and a manual.
Fast Toys ram air kit
K&N air filter
Whisper Motorsports lid -> Texas Speed & Performance lid
SLP bellow
Granatelli MAF -> stock screened MAF
Bauer racing ported/polished throttle body
LS6 intake manifold
NGK TR-55 spark plugs
Holley 9mm wires
FLP long tube kit w/ORPs -> Kooks 1 3/4 stainless steel long tube headers
SLP Loudmouth -> Custom true dual H setup w/Dynomax bullets & no cats
ASP underdrive pulley
stock water pump -> Meziere street electric water pump
MTI C2 cam 224/224 .581/.581 112
stock T-56 -> fully built 200-4R
Spec stage 3 carbon fiber clutch -> Yank PT4400
stock aluminum driveshaft -> Denny's nitrous ready shaft
stock 10 bolt w/3.42 gear -> Strange 12 bolt w/4.10 gear
chrome 10 spoke SS wheels -> Bogart bolted RTs.
6600 rpm rev limiter -> 6900 rpm rev limiter
full accessories -> removed power steering
lots of weight reduction since the 6 speed setup
6 speed setup 416.5 rwhp/387.4 rwtq
200-4R setup unlocked 362.7 rwhp/413.8 rwtq
I can understand the hp loss, but how did it pick up tq? Back then, my numbers for a 6 speed were high. Actually, my tuner said that it was the highest that he's ever seen. But from what cams are out now, my power would be normal. What do you think about my 200-4R setup numbers? That was with a Yank PT4400 unlocked, 4.10 gears, etc.? Are they below average, average, or above average? I’m not disappointed at all because I knew that it wasn’t going to put down as much, but its not all about peak numbers.
Here are the dyno sheets. I don’t have a scanner, so I just took a digital picture of them. What do you think of the curves. I dont know whats good or whats bad. Thanks.
K&N air filter
SLP bellow
LS6 intake manifold
Holley 9mm wires
