for those with vacuum gauges hooked up???
Old 12-12-2004, 10:58 AM
DeepBlueZ's Avatar
Default for those with vacuum gauges hooked up???
where did you source the vacuum? i can't find a line small enough to work with the tee-fitting that autometer gives you?
Old 12-13-2004, 01:00 PM
Blase4x4's Avatar
I don't know but if you find something please let me know. I would like to hook my vac gauge back up but have seen no easy way to do this on my 6.0l.
Old 12-13-2004, 01:18 PM
Mike94ZLT1's Avatar
I used an awl and poked a tiny hole in the line that goes to the brake booster, put the plastic fitting in there, and used sealant around the hole. Works great, and no problems in 7+ months.
Old 12-13-2004, 04:04 PM
DeepBlueZ's Avatar
i thought of this but i honestly don't think i've got the guts to try it...
Old 12-13-2004, 10:01 PM
Grimes's Avatar
you could do what mike did, or you could buy an adapter that would allow you to port off the booster line too.
Old 12-14-2004, 01:00 PM
Blase4x4's Avatar
Where would the booster line hook up on a 6.0?
Old 12-14-2004, 01:26 PM
Another_User's Avatar
I haven't looked at it, but why not cut the line going to the booster and put a T fitting in there? I haven't looked...is the booster line a solid line or something?
Old 12-14-2004, 01:57 PM
DeepBlueZ's Avatar
it's not a solid line its just HUGE in comparison to the other vacuum lines all the way in the back of the motor....it's tough to find a way to T a 3/4" hose and a 1/8" tube. i found a block fitting that will accept fittings for the smaller lines with a compression fitting to seal the little plastic tube into the third port but i can't seem to get to a vacuum line that small to make it work. they're all the way back on the intake under the cowl....(in an f-body anyway.)
Old 12-14-2004, 03:12 PM
John_D.'s Avatar
You have vacuum between the pcv and the tb, and vacuum between the purge solenoid and the front of the intake.
The purge line is a hard nylon line. I don't remember what the pcv line was, I re-did all that with my swap and the LS6 setup.
Old 12-14-2004, 04:33 PM
I was thinking about that. That is where I would have tried first I think. Now I want to get one...
Old 12-16-2004, 11:09 AM
DeepBlueZ's Avatar
update -- a buddy of mine found a vacuum source today and T-ed into it in 10 minutes.
i was too frustrated trying to find a place to tap into the vacuum so he said he could take care of it.
he didn't tell me exactly what he used but he said something about a port off the map sensor that goes to the heater controls...
not only could i not see it or feel it back there, i never even would have thought of it.
in any case, the idle is good, no codes and the gauge is showing 20 in/hg. at idle so everything seems to be good.
