Newbie Questions
Old 12-12-2004, 10:53 PM
CF7GO's Avatar
Default Newbie Questions
Hey all, I have a few questions. I just installed a 2001 6.0L and 4L80E tranny in my 1999 silverado. I have the computers from both trucks. My problem is that when I use the 2001 computer it wont even start. but when i use my 1999 it will. Here is what I have done to the motor. MTI C2 cam, Stage 2E heads, 2800 stall, and HP tuners. With HP tuners can a change my tranny from the 4l60E to the 4l80e or do i have to have it flashed from GM. When I use the 2001 computer i get a theft code. and when I use the 1999 comp. it bairly works. I have so many questions i don't even know where to start.
any help would be great thanks
Old 12-12-2004, 11:16 PM
wait4me's Avatar
ok. you have to remove the vats in each computer first, then it will let the other pcm work just plug it in, turn on the key, do a read from the pcm, then delete vats, then reflash the pcm and then you are set. as for the program needed to change to a different tranny, email me at jessebubb@yahoo.com ill set you up.. jes
Old 12-12-2004, 11:35 PM
CF7GO's Avatar
just sent you an email
Old 12-13-2004, 12:22 AM
wait4me's Avatar
emailed you back, and sent that 6l file for you too.
