How do I remove a starter on a 98 A4?
As in the title.
I wanted to remove my starter but I can't insert a socket to the lower bolt.
There isn't enough space between the bolt and the plastic cover located between the engine and the starter.
Right now I should brake the plastic
The transmission oil line are in the way also.
Who did this job already? How?
I know, it's not difficult at all but I really can't get that bolt out. I tried a wrench but it's too weak: the bolt is probably locked and really need a socket to come out.
Thanks - Stefano
Thanks - Stefano
Sweet Cheeks
There's no need to melt anything. The smaller socket will work, it just takes a little muscle. I've done it on a 98 before. That's why they went to 13mm the next year and every year after.
