TSP's New 233/239 .603/.600 Camshaft $310!!!
Old 12-13-2004, 10:47 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
Default TSP's New 233/239 .603/.600 Camshaft $310!!!
Texas Speed is proud to now offer the 233/239 .603/.600 112+2 LS1 Camshaft
Designed off our 231.237 camshaft, the 233/239 cam offers great performance for customers wanting big power with good p/v clearance!
The 233/239 camshaft features slightly more aggressive lobes than the 231.237 camshaft, but will still work with a single springs such as the 918!
Testing has shown 50+rwhp gains from stock camshafts, and a 18+rwhp gain over a 230/227 camshaft!
The 233/239 lobe design also helps to give the camshaft good piston to valve clearance. The camshafts lobes will also work well for customers wanting to run it with a bigger valve setup such as the PRC Stage 2.5 5.3L heads!!
The 233/239 .603"/.600" camshaft will be on special for $310 from now to Christmas!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 12-13-2004, 10:52 AM
matts22's Avatar
Jason, come on dude, I know you're busy, but please check your freakin pm's. I need an update. If you have time to post this message you have time to read and respond to a pm.
Old 12-13-2004, 01:53 PM
99BackNBlackZ28's Avatar
Preach on brotha!
Old 12-13-2004, 04:13 PM
Hardtop00SS's Avatar
is this a 112 LSA cam like the 231/237?
Old 12-13-2004, 07:58 PM
Zach@Texas-Speed's Avatar
its a 112...heres a clip for you guys
heres the 233/239 112 cam
http://s18.yousendit.com/d.aspx?id=2...17705CEE6B3842
Old 12-16-2004, 04:03 PM
SupahRich's Avatar
www.supahrich.com/MOV00397.MPG
Here's a working link for the sound clip from Master Chief's T/A.
Old 12-16-2004, 10:44 PM
Tally TransAm's Avatar
i have patriot 5.3's with 2.02 and 1.57 valves milled .015"
will this cam fit???
