Pulley Removal
Old 12-13-2004, 10:58 AM
Bill Bowling's Avatar
Talking Pulley Removal
I will be installing a cam, springs, pump, etc in a few weeks. Can I get the pulley off with a 1/2" Air Impact? I have an A4 but wanted to know if I could bypass taking off the starter. My starter is hard to get to since I installed the SLP Headers.
Thanks,
Bill
Old 12-13-2004, 11:26 AM
98TXFBODY's Avatar
Location: Used to live in South Texas, Now in North Carolina
you can get the bolt out with a impact but you will have to have a tool to pull the pulley off.
Old 12-13-2004, 11:42 AM
Unaffliated Racing's Avatar
There is no reason to take the starter off for a cam install. The crank bolt will come out easier if you heat it with a small torch. It will melt the lock tight and make it come out easier.
Old 12-13-2004, 12:01 PM
I8RICE's Avatar
The stock pulley is a biatch to get off but you shouldnt have to touch the starter. I used an impact to take off my asp pulley and it came out fine.
Old 12-13-2004, 12:15 PM
Droptopws6's Avatar
Wait a minute, your changing springs too right? When you pressurize the cylinders the assembly will rotate, keep this in mind.
Old 12-13-2004, 07:10 PM
~JOSHUA's Avatar
Lightbulb
Here is a tip that made my install much easier. Disconnect the coil connectors(large white connectors-1 for each bank of coils), put the socket on the crank bolt and place the end of the breaker bar on the ground(driver's side), turn the key.... and... MAGIC!! the crank bolt is broke loose with no sweat. Good luck and don't forget to use a new bolt with Loc-tite!
Old 12-13-2004, 11:00 PM
jrp
SN95 Director
jrp's Avatar
:umm:
Old 12-13-2004, 11:05 PM
Michael Ozorowsky's Avatar
why do you have to use a new bolt? What is wrong with stock bolt? Also is locktite NECESSARY? I didn't use locktite
Old 12-13-2004, 11:12 PM
jrp
SN95 Director
jrp's Avatar
its torque to yield, can only be used once. with a new bolt, exta lock tite is not needed.
Old 12-13-2004, 11:19 PM
I'm using stock bolt right now. Is that bad?
Old 12-13-2004, 11:23 PM
KLUG'S SS's Avatar
Yeah definitely use a new bolt my dumbass found that out the hard way. I ended up having to retap the threads in the end of my crank, not fun.
Old 12-13-2004, 11:25 PM
KLUG'S SS's Avatar
The stock bolt is fine to use just get a new one when you do your swap.
Old 12-13-2004, 11:28 PM
already did pulley swap. Using stock bolt.
