408ci + 200shot fuel system - what will I need?
I have a 408ci motor going in my TA right now, I plan I spraying a 200 shot also.
My current fuel system is Speed Inc fuel rails, 42# injectors and an inline pump.
I am sure I am pushing the limits, should I add another inline pump? any other suggestions?
I have a 382 with 200 shot and am doing fine on stock lines and Walboro intank. I have a kenne bell boost a pump, but it richened it up way to much even on the lowest setting. I don't like multiple pumps, too many things to go wrong, if one fails, you can still run but not safely then BOOM. I would go with a single BIG external, and big lines if you really want to be safe. My setup is great for now, and know that MTI and Lingenfelter use stock lines for most all of their big power set ups.
SDB
SDB
