Gears & Axles - Will 10 bolt Hold?
View Full Version : Will 10 bolt Hold?
nutz'00 Z28
12-14-2004, 04:39 PM
I have a M6 Z28, with basic bolt ons, nittos,spec 3 clutch and I plan on installing cam and 100shot of nitrous in the near future but i want to see what your opinions are on the rearend first?
Will a 10 bolt with moser axles, moser 4.10 gears,TA rearend girdle hold the horsepower, estimate 390rwhp, plus spray.
Or would it be a waste of time with the M6, if so what are your recommendations on rearend combo.
thanks
Race Car Driver
12-14-2004, 04:49 PM
10 bolt will last for a while in rolling start type races, but you will break it at the strip. Better buy a 9 inch Ford.
STREET SHARK
12-14-2004, 05:13 PM
not going to last long
ULTIMATEORANGESS
12-14-2004, 05:29 PM
start saving for a 12 bolt is my advice.
Tranzor
12-14-2004, 05:51 PM
If you are at the point where you even have to ask if the 10 bolt will hold, then it's probably a good idea to invest in a 12 bolt or 9 inch.
stangeater01
12-15-2004, 12:29 PM
i made 496rwhp and had a stock 10 bolt went 12.0 na and sprayed after 60' and went low 11's on 315/35/17 nitto 555
STREET SHARK
12-15-2004, 12:36 PM
Was that with an auto or m6?
stangeater01
12-15-2004, 02:34 PM
mine was a auto 4l60e with a 3200 vig and a shift kit
RAMAIRNUT
12-16-2004, 10:44 AM
When I bought 4.10s for my T/A ,the guy at LS1 SPEED asked me if I was going to race the car.He suggested that if I was planning to spend alot of time at the track(even with new axles and a TA cover)the stock 10 bolt would self destruct.Remember this is the same rear end as an S-10 truck.It is a shame that GM was so cheap.At least the Mustangs got an 8.8!I would recommend either the 12 bolt or a 9inch.They are alot heavier in weight but at least that is where the F-bodies need it to hook good. :)
777
12-16-2004, 02:31 PM
waste of time fixing the 10-bolt it should break the first time you launch good on those nittos and that spec 3
ngozer
12-17-2004, 12:10 AM
what he said.. :D
WJ SOM SS
12-17-2004, 01:35 AM
Using sticky tires or slicks, it will live for awhile if you keep the launches 4,000 rpm's and lower, if you upgrade the axles, and do the girdle cover and studbolt kit thing. Unless it's a Auburn. Drag race applications are weakest w/the Auburn carrier....My opinion only. 4.10's really wake these M6 F-bodies up, and w/that 6th gear, fuel economy doesn't suffer too badly either. WJ
BoonesZ
12-17-2004, 09:57 AM
it will say goodbye really soon
peterock98
12-17-2004, 11:36 AM
The first time you hook good at the the track that 10 bolt will go boom.4.10 gears cost 600 bucks installed,400 if you install the yourself.That could be money toward a 12 bolt or 9 inch.
