P0101 Help
Old 12-14-2004, 08:58 PM
mikes02ls1's Avatar
Default P0101 Help PLEASE!!!!
I threw a P0101 while driving in 6th @ 81MPH. It say that it is a MAF or VAF
CKT RANGE/PERF MAF (LB/M) 1.42. I have a KnN Filter on my car with 47,800 miles. I'm thinking it is my MAF what do u tuners think?
Here is my freeze data.
P0101
ABSLT TPS (%) 24.3
ENGINE (RPM) 2273
CALC LOAD (%) 20.0
MAF (LB/M) 7.21
MAP ("HG) 23.0
COOLANT (F) 196
LT FTRM1 (%) 13.3
ST FTRM1 (%) -0.8
LT FTRM2 (%) 10.2
ST FTRM2 (%) -3.1
VEH SPEED (MPH) 81
FUEL SYS1 CLSD
FUEL SYS2 CLSD
Any help would be great, it runs like popo if u let off the gas in 6th then stomp on it, just starts to buck and sputter. only in 6th this happens.
Thanks
Mike
Old 12-15-2004, 03:55 PM
Scotts 02 SS's Avatar
Default Po101
I have had the exact same trouble many times. 6th gear.1850 rpm at 80mph =stumble = PO101. With the stock Maf putting the screen back in stopped it and with a descreened recalibrated LS6 Maf, I had no screen to put in so I turned the Maf 90 degrees and the problem went away. I think the airflow does not flow even over the Maf wires with the screen removed. Rotating the Delphi 85mm Maf 90 degrees so the filiments were in a different place in the airflow just happened to work. Now PO101 has not come back and the car runs great. Hope this helps cause I have been fighting this for some time and found nothing wrong.
Old 12-15-2004, 05:57 PM
mikes02ls1's Avatar
Yeah I Have The Screen On The Maf Never Took It Off.
Old 12-15-2004, 08:04 PM
Billiumss's Avatar
Did you just clean your K&N Air filter?
Take your MAF apart and clean it. Use Q-tips and rubbing alcohol. Be careful!!!
Old 12-15-2004, 08:34 PM
mikes02ls1's Avatar
Maybe three months ago. I just cleaned it with carb cleaner, so far it works like champ. I still need to retune the car for 4.10.
Thanks.
Mike
Old 12-15-2004, 08:41 PM
Another_User's Avatar
Old 12-15-2004, 09:31 PM
WS6FirebirdTA00's Avatar
if it was a bad maf the fuel trims would be maxed out
Old 12-15-2004, 10:10 PM
mikes02ls1's Avatar
What do u think it is? Also today I threw a P1153 code.
Old 12-15-2004, 10:34 PM
i would start at cleaning off all the maf stuff. LTFT look really high too they should be around 0%. whats the other codes definition? what are the idle fuel trims ?
Old 12-15-2004, 10:49 PM
mikes02ls1's Avatar
Yep. I cleaned the MAF no SES anymore for now.
Thanks
Old 12-15-2004, 10:59 PM
sweet
