Can a walbro gss340 keep up with -8an feed line?
I am planning on running a single walbro 340 through a -8an feed line to the rails, through a regulators, and using the stock feel line as a return. WIll the single pump be able to keep enough flow through that big of a feed line?
Size of the line is irrelevant ( to an extent ). Flow will be dictated by its final outlet and/or the regulator. The pump will flow the same fuel through a -8 line, as it will a -12 line for example. Perhaps if you were to go to a -4 line it would flow less, but nobodys likely to do that.
