Ordered Z06 MAF, got SLP...should I send it back?
Old 12-16-2004, 02:22 PM
V-10 Killer's Avatar
Default Ordered Z06 MAF, got SLP...should I send it back?
I'm just wondering if you guys think the SLP 85mm MAF can be tuned as well as the Z06 unit?
Old 12-17-2004, 05:06 AM
Billiumss's Avatar
To have less tuning headaches, put your stock MAF back on unless your making more than 500+ RWHP...
Old 12-17-2004, 06:25 AM
Seems like a waste to run a 90mm intake and throttle body, and a 75mm MAF.
And unfortunately, I sold the old airlid, MAF, TB, and LS6 intake to get some funds together for the 90mm FAST setup, so I'm kinda stuck with it.
I'm not making 500+rwhp yet, but I'm hoping I can pull low to mid 400's for now, with the TSP 231/237 cam and TSP LS6 Race heads. I'm trying to get everything ready for the 402 stroker next year, and am kinda limited to buying one or two pieces at a time.
Old 12-17-2004, 12:46 PM
DTSNGIT's Avatar
I agree it is a waste to run all the 90MM stuff and a 75MM MAF. But don't buy any aftermarket MAF. Instead buy the 85MM Z06 MAF from 2002 or later. Very easy to tune and only $100 or so ........
Mike
Old 12-17-2004, 01:58 PM
Bill Bowling's Avatar
Talking
Mike
Do you have the Z06 MAF part number?
Thanks.
Bill
Old 12-17-2004, 02:05 PM
What really throws me off here is that the sponsor that sold it to me says "the sensors are identical as far as fit and performance, really it is just 2 different companies re-boxing them."
Now I've never heard that about them before.
Old 12-17-2004, 02:57 PM
horist's Avatar
I believe they are identical... SLP puts a resistor inside the MAF so that the PCM doesn't need to be modified on F-Bodies... the LS6 MAF tables are different than LS1 MAF tables... w/the SLP they trick it so you don't need the new MAF Tables
Old 12-17-2004, 03:40 PM
jason5's Avatar
i'm using the zo6 maf, and using the zo6 maf table, but when you do that it makes the car run lean, i had to tune the ifr, to get it right but runs good.
