jet-hot "Y"???
Originally Posted by LS1SS4ever
What specife u want ?
basically i just want to know if theres any fitment issues,or ground clearance probs.and the removable cats are internal, right?like theres no shell showing on the outside,right?
Originally Posted by TAQuickness
comes in 5 pieces and an assortment of u bolts and clamps.
well i'd get it welded toegether.so then i'd assume that it'd be cool,then.
Welding it would most likely damage the coating.
JetHot just release a brand new 2-piece OFY. It's the exact same price as the 5-piece one and is currently available. I know this because our company sells JetHot headers.
The catted Y is a different story, it does come in 5 pieces because you can remove the cats. And yes, they are invisible once installed. I know that getting all the pieces lined up and tightened can take some time.
If you do get their y-pipe, dont use the crap u-bolt clamps, go buy some stainless band clamps for exhaust applications. They seal much better and are very good quality.
thanks Josh, i will definitely do that.keep the feedback coming.
Originally Posted by '02SS
any other opinions on the jet hot y?
I JUST finished putting my JH LT's in with the catted y-pipe. Things went fairly smoothly, and the y-pipe wasnt too bad to install. Had to push and pull and line everything up really well, but other then that, it was pretty straight forward.
thanks Josh.im definitely going to do this setup.thanks everyone.
LS1TECH Sponsor
love the headers had there "catted-y" fitment wasnt to bad , have a hooker ory now tucks up a lil better .
however the jet hott cats dind last long at all do some searchs and youll see they will fall apart quickly which was kinda dissapointing
