ngk problem
ngk problem
I just got a new set of NGk's and wires, are these pregapped?
My car stumbles when I first get on the gas and just seems all around sluggish, and yes I did the 2 click rule and have checked the wires again and again.
I assume you didn't gap them before putting them in?
Ditto on the above comment. Also, sometimes a wire or boot is close to failing, and the act of replacing the plugs is enough to push them over the edge. If you're getting arc-through you can often see it as a blue glow or discharge off the wire or boot when viewed in total darkness. Usually arc-through will happen closest to the plug end, but not always. I put on Taylor Thundervolt wires, and they're built like a brick outhouse, so you might want to do the wires as a matter of course, if the old ones are original.
need help on #8 plug, ne suggestions on taking it out and installing newones? just did install today and i have all of them in xcept that one. btw freakin fixed my problem muchas gracias NGKs!!!!!!!!
I have found the best way to get the #8 is to use a 1/4 drive ratchet with a 1/4 universal and a 1/4-3/8 adapter with a normal size spark plug socket. I also remove my air tube from my headder and push it to the side which allows me to get my arm down in there. Should be able to brake it loose if it is not to tight. And when going back in I put a SMALL dab of anti-seize for the next time makes it even easier. If it is real tight migh be able to use the spark plug socket with the wrench flats to brake it loose. I have never replaced it from below, worse for me with the headers. Just remember to start the plug by hand with the socket and extension, and then tighten down when you can no longer turn it by hand and you know that it is not cross threaed.
With this ratchect and universal set up I have been able to replace all my plugs in about 30-45 min. Cold engine . Still come out with arms all scratched up but thats the fun of working on your own car.
Chris
Chris
Thats the type of wires I just replaced, they were the biggest piece of **** ever.
