Can you have too much injector?
12 Second Truck Club
What kind of problems can you have if you have injectors that are way overkill? Say you only need a 60# but you install 90#? TIA
You would loose resolution at idle, and low power levels. Meaning that you would not have the precise control to get your idle and cruising fuel setup as well as you would be able to with the smaller injector.
