Got the numbers Good/bad?
Old 12-18-2004, 11:14 PM
35thls1ss19's Avatar
Default Got the numbers Good/bad?
I just dynoed my car today, with all the mods i have in my sig i put down 335.71RWHP and 356.49 RWT. Is there where i should be? Just wanted some feed back. Thanks!!
Old 12-19-2004, 06:18 PM
Nate_Taufer's Avatar
yeah that seems right...now get a cam to take advantage of all that extra airflow.
nate
Old 12-19-2004, 06:58 PM
5POINT7's Avatar
Seems on the lower side of the spectrum for your mods. M6 02's dyno higher than most any other f-bodies. You are in the range you should be, just a little low in that range.
Old 12-19-2004, 07:09 PM
1BadMoFo's Avatar
Looks pretty darn good for just LT's, ORY, and exhaust if you ask me...my Lt's, ORY, and exhaust only yielde me 330 rwhp and rwtq....so you should be quite
Old 12-23-2004, 01:57 PM
ynkssws6's Avatar
Hmm....weaksauce. lol j/k man, sweet numbers.
Old 12-23-2004, 02:31 PM
Kleeborp the Moderator™
MeentSS02's Avatar
Mine with similar mods with cats dynoed 331/347. I'm getting an after dyno as well after I get my true duals done to see if that frees anything up. I have a feeling my tune is off, but I haven't gotten a look at my AFR yet.
Old 12-23-2004, 02:51 PM
Avengeance's Avatar
I would be wondering about those numbers... Ill be honest Id be pissed with only 335rwhp and those mods.
My 35th LE did 353rwhp and close to 370rwtq with TSP LID, K&N, Jet Hot LTs, Jet Hot ORY, and cutout.... not tuned.
What was your A/F?
Old 12-23-2004, 03:50 PM
TEA Brent's Avatar
Those numbers would be ok if you had an ls1 intake. How was your a/f and what was timing. Could be a tuning thing.
Old 12-23-2004, 04:35 PM
MeentSS02's Avatar
Geez fellas...I'm kinda happy with my numbers (the 331/347), and the only thing that's really different is that I'm running cats and a Hooker catback. My AFR was apparently 12.9-13.1 on mine...
Just cuz it don't dyno high doesn't mean that something's wrong with it. I've always been happy with how mine has run next to other cars with similar mods.
Old 12-23-2004, 07:17 PM
Avengeance's Avatar
Well.. you did ask.
As long as youre happy with it thats all that matters!
Old 12-23-2004, 08:00 PM
MeentSS02's Avatar
Originally Posted by Avengeance
Well.. you did ask.
Actually, I didn't ask anything. I just posted what my results were with similar mods so he'd have another data point to work from. I think his car is right where it should be for the average bolt-on '02 f-bod. That is just my opinion.
Old 12-23-2004, 11:34 PM
Avengeance's Avatar
My bad.. I misstook you for the thread starter.
Old 12-24-2004, 12:41 AM
What was your A/F?
I have never had a tune and my air/fuel was perfect like 12.... And i dotn no if it matter but the humidity 28% and it was 60 degrees out.
And also i notice we are runing the same times when u had just your exhaust, i wonder if it was a shitty day what u think?
Old 12-24-2004, 01:40 AM
Avengeance's Avatar
Maybe weather, its possible.. I wonder if they had a correction factor for conditions. The dyno I use corrects everyones dyno #s to a specified temp/humidity.. therefore you have accurate dynos between not only different cars but even your own.
My 12.8 was on a stock clutch with 37K.. it was deffinately on its way out.
Lots of things could be a factor.. Id like to see your AF... cause a "12" is kinda vague. Lots of power can be had going from a 12.1 to a 12.9 AF.
Old 12-24-2004, 02:48 AM
LSs1Power's Avatar
The TQ looks right on, but the HP is 10rwhp lower or so. Check Sig to compare.
Old 12-24-2004, 07:01 AM
ynkssws6's Avatar
His numbers are SAE corrected.
Old 12-24-2004, 04:05 PM
LS1_PNYTAMR's Avatar
wow those are all really really good numbers guys..
Old 12-24-2004, 06:38 PM
yea my clutch is on its way out too, and i have 20k on the car. I will scan my dyno sheet in and then pm you and send you it so you can check out my a/f. Thanks again! this stuff drives me nuts
Old 12-24-2004, 07:03 PM
Ojustracing's Avatar
Ck my Sig!! My car had about the same but the AFR was wrong at 14.+- for most of the run. I havent had the car back on the dyno since to see what the updated numbers are. Good Luck. John
Old 12-24-2004, 07:26 PM
Avengeance's Avatar
No prob man... send it over when ya get the chance.
Ojust... 14 AF?!?!?!
