What size dual exhaust for 440HP motor?
I have long 4-1 headers which are 1 5/8" into 2 1/2" collectors.
Should I continue the whole system at 2 1/2" dual or go 2 1/4" dual?
Engine makes 442HP at flywheel.
Also does anyone use/recommend Borla Pro XS mufflers for quietness and good performance?
2 1/2 if you're only going that big of collectors, should be good, borla xr-1 i'd say(the one that looks like an oval muffler not a bullet 100% straight through muffler)
It's not mine! woo hoo!
Originally Posted by zchgla
Is 2.5" not too small for 440hp? Most people I see usually get 3" exhaust when they have about 380+rwhp, although they have 3" collectors.
Originally Posted by Mooobunnny
2.5'" exhaust can support 1000hp, but the same motor would make 1100 with 4 inch exhaust
Anything beyond bolt-ons and I would recommend 3 inch atleast to the x-pipe or crossover.
Chris
Chris
Kleeborp the Moderator™
Originally Posted by psykoTa
Ok, what I meant is it can handle 500HP with out causing any loss of HP or torque. So if you had 500HP, and went to 3", then you would see very little gain. I am curious as I am going 3" to the X-pipe, then 2.5" out the back. Next year I am planning on a cam with intake, TB, etc....So am I right about 2.5" supporting 500 with out any loss?
I really don't think it would be that much. My exhaust being fabbed now is 3" into the x-pipe with the rest being 2.5" all the way out the rear. I really need 2.5" for clearance since my car is lowered. I have big HP goals in mind that will be reached with nitrous, but I'm having the exhaust made in such a way that I can drop a vast majority of it and just run some dumps on the headers if I ever feel like my engine is being choked.
I just like to think of it kinda like the cats vs. no cats debate. There are people out there with dyno proof that cats are really restrictive, and there are others with just as much proof that cats aren't really all that restrictive. Who do you believe?
It is kinda one of those things where you just have to take anything you find on here with a grain of salt. What works for someone may not work for others. There are people that drive huge cams daily and think it is acceptable. There are others that think a TR224 is too much for a daily driver. All depends on who you're talking to.
