Broke 2 Wheel Studs from Rear!
Broke 2 wheel studs from the rear! Is there anyway I can replace them without opening the gear box/ differential cover and taking out the axles? Thanks!
Just take the rotor off and use a hammer to knock the old studs out. Then slide the new stud in from the back, and use a spare open-ended lug nut (NOT the lug nuts you use to mount the wheel) with a couple of washers between it and the axle flange (to keep from gouging the flange face) and crank down on it until it pulls the stud all the way in.
